tranny leak
tranny leak
I just bought a 78 camaro. when my car sits for a long period of time I get tranny fluid all over my floor. it has new front seal so I know that's good, please help!
RE: tranny leak
I've had more than a couple of cars that would do that. My 69 used to pee a small puddle if it sat for more than a week without driving, and a lot after a long winter's nap. Yours is more than likely leaking from the stock loose-fitting aluminum speedo cable gear housing on the side of the trans. Even a new o-ring didn't help mine. I found a very well made, machined steel gear housing on ebay. Slapped that sucker in, and it stays bone-dry now.
Here you go, I found it:
http://cgi.ebay.com/ebaymotors/Chevy...QQcmdZViewItem
RE: tranny leak
okay you got me. I unhooked the speedo cable awhile ago to work on it so that is probably it. boy I bet you guys really get a kick out of stupid questions. lol
RE: tranny leak
ORIGINAL: 92 RS in training
And, if you only disconnected the cable but didn't remove the gear housing, then it would still be the gear housing that's leaking. I would still recommend replacing it with a good one. A lot of times, that's one of the last places people think to look for a leak.
BTW, a tailshaft seal isn't going to leave a big puddle unless the trans is overfilled or if the car is parked uphill, since the trans fluid doesn't rest quite as high as the output opening of the seal. The opening for the speedo on the tail however is a bit lower than the rear seal is, making it the first one to want to leak.
