Towing 79 Z28
Just tell them you want a plastic plug to fill the tailshaft when you pull your driveline. I've pulled a lot of cars with a two wheel dolly and the driveline removed. They tow beautifully and it's much lighter than any other method, so less weight to pull.
Instead of pulling the driveshaft completely, you could leave it in the trans and use a tie-down strap to hold the back end securely up and out of the way, while also making sure it can't slide back.
You can tow it neutral. In the tow industry, they say that not to exceed 35mph for no more than 10 miles (with an auto trans). They say it will "blowup". Manuals: neutral no problem.
My dad (2nd gen gearhead/his own big rig mechanic) says its crap with towing auto trans because the pump is on the input shaft so when the output shaft/driveline are spinning, there is no pressure.
In my opinion between towing either on flatbed or wheelift, around town or to a fellow gearheads house, dolly rwd in neutral (or tow dolly it backwards and secure the steering wheel with a ratchet
strap) is fine. But if you are going out of town, I would use a car trailer. Most full size P/Ss can handle it.
Thats what down shifting is for!
The pumps are on the input side, but fluid will circulate regardless of whether the input or output shafts are turned, the difference is the trans is in neutral, so it wont move. Revving your engine in neutral is OK, because the trans is designed for flow that way, but turning the output shaft, with the converter not spinning can and will damage a trans if you go over the reccommended speed of the manufacturer.
In normal operation the pump is run off the engine, so not only does it provide pressure to the clutches, it also provides important lubrication to the trans, and cooling. When towing you have neither lubrication or cooling, and you'll damge the trans from lack of either.
