1980 camaro 4-speed conversion
Old May 4, 2007 | 11:51 AM
jbe123's Avatar
Default 1980 camaro 4-speed conversion
How hard would it be to convert my 3-speed auto over to a 4-speed manual?? Can i get a 4-speed to just bolt right up right where the old one was??
Old May 4, 2007 | 05:31 PM
thebandit110's Avatar
Default RE: 1980 camaro 4-speed conversion
yeah u could get a 4 speed to bolt up. the hardest thing would prolly be be the linkages like clutch pedal and stuff. unless they have a kit or u can find an original clutch pedal and use that linkage and what not. also u may have to change ur drive shaft. pending on what tranny u get. most of the mounts should be similar also. so it can be done. prolly alil thinking involved. if ur like me and thinking hurts just stick with the auto and beef it up. shift kit and what not. performance torque converter and things along those lines
Old May 6, 2007 | 02:26 PM
rat454's Avatar
It's not too bad.
just takes time and the right parts. There are several suppliers out there that sell the parts....
check out:
http://camarocentral.com/files/4-Clutch.pdf
I did the Tremec conversion.
Greg
Old Jul 23, 2007 | 02:39 PM
TheDrivenMan's Avatar
We have all of the parts you need to make the swap in one spot. IM me if you are still looking to make the swap and I will be glad to send you an estimate.
Old Aug 6, 2011 | 10:57 PM
dwg's Avatar
dwg
I have a 1980 z28. I want to convert to a 4 speed. Do you have everything I need to do this? If so please give me a price list on all parts I need.
Thanks
David
Old Aug 7, 2011 | 07:53 AM
v8chvyguy's Avatar
I would suggest a 5 or 6 spd. I'm running the original super T10 with 3.08's in the rear and I still don't have enough gear. You'll have more fun driving the car, but, cruising won't be much different. All the final drives are 1:1, 4th gear is no different than 3rd in your automatic.
Old Aug 7, 2011 | 08:02 AM
Thanks
David
To avoid digging up dead threads, be sure to check the date of previous posts. That one you responded to was a 2-post wonder, and also the last day that guy ever logged on here again (7-23-07). Just a guess, but I don't think you're going to hearing back from him.
Old Aug 7, 2011 | 09:16 AM
This is funny!
Old Aug 7, 2011 | 12:23 PM
We are going BACK to the future...
Old Aug 7, 2011 | 11:50 PM
v8chvyguy's Avatar
Well that was a nice round trip.
My recommendation still stands.
DiElSleL
Mar 6, 2012 10:54 PM
jeu510
Feb 13, 2012 07:55 PM
Chevyfan99
Apr 19, 2008 12:34 PM
Shmack2004
May 31, 2007 04:26 PM
