torque converter bolts...again
Old Mar 24, 2008 | 11:18 PM
thebandit110's Avatar
Default torque converter bolts...again
okay, i got shorter bolts for my torque converter. but the space for the nuts is to short for the stop nuts i bought. do you think a regular nut with lock tight is okay? or what do you think is best. thanks
Old Mar 25, 2008 | 12:07 PM
1969 SS's Avatar
Default RE: torque converter bolts...again
absolutely not!
you need to buy the proper grade bolts for that application. use the proper bolts and then use blue loctite
Old Mar 25, 2008 | 02:12 PM
well the bolt that runs through the pressure plate and the T.C. are case hardend steel. and the nut is a regular stainless steel nut. just the space in the t.c. cannot fit the nut with the nylon plastic in it. and can i use the red lock tight? i know the blue is medium strenght? thanks
Old Mar 26, 2008 | 08:31 AM
bowtieguy's Avatar
July 2009 ROTM
i dont think the original nuts are nylon locking nuts.the original nuts have a wide base with the raised grooves built in that act as the locking mechanism.i wouldnt use the red lock tight ,maybe the blue.you get the right nut and you shouldnt have a problem.those locking nuts are a little bit taller not allowing them to slip into the pocket like they should
Old Mar 27, 2008 | 12:01 PM
1969 SS's Avatar
ORIGINAL: bowtieguy
forgot to mention about the nuts. bowtieguy is correct about what the right nuts should look like, and I didn't know you were talking about nylon locking nuts, because I wouldn't have even thought anyone would use them in an application that sees so much heat.throw them away!
if you get all the right stuff, you will have no problems down the road. honestly, they are special application nuts and bolts for a reason
also, stay with the blue loctite
Loess Hills
82-92 V8 Tech
Sep 27, 2011 02:52 PM
freaky
Mar 13, 2010 12:28 PM
clyon
Oct 24, 2009 06:00 PM
kerbykk
Oct 7, 2008 09:08 PM
73 T Top
Apr 3, 2008 12:51 AM
