is there a way to stop the squealing sound when wet?..
Old Oct 15, 2008 | 08:10 PM
  #31
kyphur's Avatar
Default RE: is there a way to stop the squealing sound when wet?..
are you using a regular bolt or does the bolt have "grip teeth" across the bottom of the head where it sits against the bracket?
Old Oct 15, 2008 | 08:24 PM
  #32
jason7504's Avatar
pretty sure its just a regular bolt
Old Oct 15, 2008 | 09:24 PM
  #33
I've always useda regular bolt and never had a loosening problem. I wonder if you're still not tightening the bolts enough? Try using a star washer or a lock washer. Those will dig into the bracket better.
Or, if you want to get some treats for your engine, a set-up like this is trick, and your alternator ain't gonna budge: Alternator Bracket
Old Oct 16, 2008 | 12:18 PM
  #34
jason7504's Avatar
well i tighten it pretty tight..ok i might get one of those and try it..mise well lol..oh that would be a nice addition lol..so you think that would hold my alternator pretty tight?
Old Oct 16, 2008 | 12:35 PM
  #35
The top bracket acts as a turn-buckle. Loosen the two lock nuts, and crank the center portion of the bracket till the belt is tight, then tighten the lock nuts. Unlike the slide bracket you're now using, this can't loosen back up on it's own.
Old Oct 16, 2008 | 12:59 PM
  #36
jason7504's Avatar
ok that sounds sweet! i might get that since the squeaking is driving me crazy..i mean you dont wanna hear a squeak, you wanna hear the engine roar! lol thanks camaro
Dana
Sep 23, 2013 11:37 AM
nouturn20
Oct 11, 2012 02:02 PM
Guitar
Jul 17, 2011 09:51 PM
blakoma
Jun 27, 2007 08:23 AM
crystal27lt
Apr 5, 2007 09:49 PM
