another rear end question
Old Oct 9, 2008 | 08:47 PM
speedy9220's Avatar
Default another rear end question
stock rear end in 80 rs...... lookin to put 3.73 gears in it. is this what i need? do i need anything else? a tranny shop will do the work for me. any other suggestions?
Eaton Torque Control Products 19557-010 - Eaton Posi Performance Differentials - summitracing.com
Richmond Gear 4900411 - Richmond Gear Ring and Pinion Sets - summitracing.com
Old Oct 14, 2008 | 08:46 PM
speedy9220's Avatar
Default RE: another rear end question
Old Oct 15, 2008 | 05:40 PM
got3ofem's Avatar
Did you have a chance to count the splines on the pinion you have now? If itsa 30, you should be good to go with the set youpicked out.
Id still suggest youget a master bearing w/seals set, If you are going to pay a shop to do the work, they should have suggested that anyway, and be sure to have them inspect the axles for unusual wear and/or rust.Also, make sure you get a new crush sleeve withany kit that you buy..
Old Oct 16, 2008 | 03:50 PM
speedy9220's Avatar
i didnt get a chance to count them yet but thanks for the info. a shop will most likely do the work for me. thanks again i appreciate it
auto
Aug 14, 2012 08:08 PM
JPrice
May 20, 2012 03:48 PM
meteoralp45
Mar 22, 2010 08:47 PM
meteoralp45
Mar 12, 2009 07:43 PM
asdfghjkllkjhgfdsa
Mar 22, 2007 11:55 PM
