Tachometer question?
Old Jul 29, 2010 | 08:02 PM
Vet76te's Avatar
Default Tachometer question?
When I turn my key on and crank the engine over, the tachometer needle pulses downward, (counter clockwise),...but when it starts, the needle retrurns to the resting nuetral position and doesn't move at all.
What does this mean? What is the diagnosis?
Old Jul 29, 2010 | 09:03 PM
Sounds like one of two things. Either the tach isn't compatible with whatever ignition system you have, or it's reversed polarity. Mine drops to below zero when the key is off, but as soon as I give it power it comes up to zero, and then to engine rpm when I fire it.
71CamaroZ28
Apr 24, 2009 11:12 PM
1979RS
Aug 17, 2008 12:10 PM
milferd3@yahoo.com
Jan 19, 2008 07:54 PM
camarohelp
Jan 15, 2007 07:39 PM
burnout
Jan 9, 2007 06:31 PM
