Sway Bar Bushing
Old Apr 22, 2006 | 06:25 PM
shnormo's Avatar
Default Sway Bar Bushing
I got a 79 Z28 Camaro and I was wondering what the size of the front sway bar was. I want to buy energy suspension bushings, and if anyone has done this, could you also please include the part number.
Old Apr 23, 2006 | 09:06 PM
1969 SS's Avatar
Default RE: Sway Bar Bushing
if you are just going to buy stock sized replacement bushings, they will be able to pull the part numbers for you real easy when you order. it doesn't get any easier than stock replacements
Old Apr 23, 2006 | 11:02 PM
v8chvyguy's Avatar
My 79 Z is stock and she has 1 1/8 front and 5/8 rear.
Old Apr 23, 2006 | 11:30 PM
bowtieguy's Avatar
July 2009 ROTM
there are 2 different size front sway bars.there is a 7/8 and a 1 1/8.the back is a 5/8.i think the z-28's had the 1 1/8 front sway-bar.the coupes had the 7/8 front sway-bar
Old Apr 24, 2006 | 02:01 AM
shnormo's Avatar
It was a 1 and 1/8" sway bar. Energy Suspension has a printable measuring tool on their website that proved to be very handy. Thanks for your help. I didn't want to go with stock ones, I wanted to go with greasable polyeurothane to make it handle better. I used poly graphite in the back, leaf spring pads, shackle bushings, and shock bushings. For the front I went with poly graphite for the control arm bushings (more expensive than polyeurothane) they glide better with less squeak. I then used Energy Suspension poly eurothane for the sway bar end links, shock bushings, steering boots, ball joint boots, and sway bar bushings.
Old Apr 24, 2006 | 01:55 PM
bowtieguy's Avatar
July 2009 ROTM
use your head and measure the sway bar before you buy new bushings .you dont buy new shoes before you try them on do you.
Old Apr 24, 2006 | 03:21 PM
shnormo's Avatar
I did measure it hence the print out from energy supsension ****** bag. Hence I know it is a 1 1/8" bar for a 1 1-8" bushing. I was just looking for a quick reference... that's why we have this forum isn't it?
Old Apr 24, 2006 | 08:40 PM
bowtieguy's Avatar
July 2009 ROTM
exactly my point,i asked about the crossmember and you said use your head.i was looking for someone's input that had already been through the transmission swap and knew what they were talking about.your right that's what this forum is all about,helping our fellow camaro owners with problems we have already experienced.****** bag,that hurt my feelings man (LOL)
chevcamaro
Dec 5, 2011 12:06 PM
o2camaross
Aug 26, 2007 05:20 PM
Z28rook97
Apr 14, 2007 11:12 PM
shnormo
Oct 21, 2006 12:34 PM
AoWJP
Apr 4, 2006 03:31 PM
