Stuttering in Vegas heat
Old Jun 6, 2017 | 03:27 PM
pmnj19's Avatar
Default Stuttering in Vegas heat
I've just moved to Vegas with my 79. The issue I've been having is when it gets hot out, and the engine really heats up the engine will lurch and stutter when I lay into it too much. Originally I figured it was an issue with it not getting a spark, or enough spark, but talking to some of the local out here I've been told it could be the exhaust causing the gas to boil. Without any of the tool or expertise I had back home I'm stuck with trusting a mechanic. Just wanted a second, non-biased opinion or the matter from someone who surely know the car better than I do.
Old Jun 7, 2017 | 08:03 AM
Cheeks's Avatar
August 2011 ROTM
I've heard of that on more than one occasion.
A lot of times it will fill the bowls up with boiling fuel and not be able to fuel correctly. In some cases, a fuel cooler may be needed like on the newer diesel trucks
Old Jun 7, 2017 | 09:50 AM
Everett#2390's Avatar
Yes, could be the gas is vaporizing in the fuel line from pump-to-carb.
A quick fix can be wooden clothes pins on the tubing for dissipating heat,
and/or wrapping fuel line with pipe insulation.
Another fault may be the coil in cap getting too hot, exchange coil or use another cap with coil when it happens. You might drill some holes in cap for flowing of cooler air through it.
Old Jun 7, 2017 | 04:59 PM
I've had that happen, where the carb was getting too darn hot, and the gas would perk out of the bowl faster than it could fill up. One thing you don't need/want on a hot weather car, is the stock setup that cross-flows hot exhaust beneath the carb. Great for heating it up in winters, not so good at all in hot weather, which is what you may be finding out. Blocking those ports off requires removing the intake manifold though, and installing the block off plates. A bandaid fix would be using a phenolic carb spacer, which will help cut down the amount of heat that transfers to the carb.
burning camaro
Nov 9, 2010 06:15 PM
CamaroTeen
May 19, 2009 03:01 AM
bezerker
Mar 28, 2009 11:12 PM
brassknukl
82-92 V8 Tech
Aug 7, 2007 05:16 PM
87camaro
Apr 5, 2006 05:26 PM
