still having headlight trouble
Old Sep 17, 2010 | 07:20 PM
Bing's Avatar
Default still having headlight trouble
On my 80's camaro i'm having trouble with my head lights.
At first, it was just that the right side was dim and the turn signal didn't work. i found the ground and repaired it and that fixed the dimness problem. However, when i put the right turn signal on all the lights flash, as if i had the emergency lights on. When i turn the left turn signal on nothing happens.
Seeing as all the lights are going off, i thought i'd add that the emergency switch on the steering column broke off. soooo, that MIGHT be a problem.
any ideas?
Old Sep 17, 2010 | 11:20 PM
any ideas?
Yep! I'd say fix the emergency flasher, as if it's stuck on they'll all flash.
Old Sep 18, 2010 | 01:30 PM
Bing's Avatar
well im pretty sure the switch isn't stuck on, seeing as they all don't flash unless i put the right turn signal on. Other wise, the lights all work fine. But i'm looking into fixing it... i don;t wanna take apart the steering column, and i think that's the only way to get to it. :/
Dana
Jan 28, 2012 12:57 AM
hotrodz28454
Mar 23, 2010 03:13 AM
blink18236dude
Jul 10, 2007 10:53 AM
hoppinchevy
Oct 30, 2006 12:21 AM
81CanuckZ
Sep 10, 2006 11:04 PM
