steel 2inch cowl hood fitting?
Old Mar 13, 2011 | 04:49 PM
stox58's Avatar
Default steel 2inch cowl hood fitting?
I've just installed a new steel 2inch cowl hood ( reproduction part ), seems to fit very nice. Until i tryed my wipers and realized that they hit the cowl and will not operate.
I have the hide away tyoe of wipers, the only think i can think of is to modify the hood to give them enough clearance.
Has anyone else come accross this issue, or can think of any other solutions?
many thanks from Luke
Old Mar 13, 2011 | 05:31 PM
ATM's Avatar
ATM
Old Mar 13, 2011 | 09:31 PM
Here's a link to a PDF file that should explain it all. If your car didn't have hideaway wipers originally, then that may be the issue, or if you have the wrong type arms it may be the issue. Check this link out:
http://www.nastyz28.com/2gcog/wipers.pdf
Old Mar 14, 2011 | 01:00 PM
stox58's Avatar
Mine is a 77 so would have been hide away as standard. I will double check the arms, just to make sure that another owner didn't replace one with the wrong type.
thanks
Old Mar 15, 2011 | 02:41 AM
stox58's Avatar
I beleive evrything is ok with the wipers, correct colour and extra linkage on the drivers side.
The only other thing i can think of is adjusting the bump stops, this may sort the wiper clearance, but i think the hood will then be above the fenders.
Is there any adjustment that can be made to the hood hinges?
Thanks from Luke
Old Mar 15, 2011 | 09:00 AM
Nothing you can do to the hinges or bump stops that wont raise the hood and lead to it not matching the fender height. Yes, the hinges can be raised where they attach with two bolts.
What brand of hood is this? Have you contacted the supplier to ask if they've had other issues with this problem. Do you drive the car a lot in the rain? I don't even run wipers on mine, as the only time I'm in the rain is if I get caught in it. I RainX my windshield and it works good enough to keep it clear if I do get caught out in a shower.
Old Mar 15, 2011 | 01:13 PM
stox58's Avatar
Not sure of the make of the hood. I will have a another look at the weekend and see if i can sort it. If not i will be contacting the supplyier.
I dont take it out in the rain, but i think it would fail it's MOT if the the wipers dont operate.
Old Mar 15, 2011 | 04:54 PM
So I guess you could raise the hood to get clearance, then after it's inspected drop it back down to match up properly. Or do they do random checks too?
Old Mar 15, 2011 | 05:41 PM
7T3Z28's Avatar
June 2012 ROTM
Humm got the hood on, car still in progress, have not checked turning on the wipers.
Thanks for the heads up.
Old Mar 15, 2011 | 09:23 PM
Mine cleared fine, but I don't have the concealed type wipers. I don't run them any more just because I don't have clearance with my gauge mounting.
