starter problems
Old Feb 25, 2009 | 09:55 PM
79blueberry's Avatar
Question starter problems
aight so ive put 3 starters in my camaro in the past year and tryed evry type of shiming and the the 3rd one is in now iand i alomost got it figured out untill today when i wwnt to start it and the starter isnt even engaging the flywheel i have no idea whats wrong if anyone could help id bee thankfull and can a starter break the teeth off the flywheel just wondering
Old Feb 25, 2009 | 10:16 PM
Your starter gear is too far away from the flywheel. And adding shims is dropping it even further away. I presume your starter was making a loud whiny gear noise? What you need to try is to take out all the shims and put some shims between the starter and block at the outboard bolt only. That will rock the starter closer to the flywheel gear. I just went through this same issue with mine this summer. I even had to grind off part of the mounting surface on the starter flange at the inboard bolt area to bring it up more.
Old Feb 25, 2009 | 11:03 PM
thats exactly what ir was doin and ill deff try that in the morning thanx for the help man and just making sure is the outboared bolt toward the block or tranny
Old Feb 25, 2009 | 11:44 PM
The outboard bolt is the one farthest away from the flywheel, inboard is closest to the flywheel.
Old Mar 6, 2009 | 09:57 AM
dingo0722's Avatar
I would also count the number of teeth on the flywheel. There are different flywheel gear pitches for these engines. If the flywheel has ever been changed to a different pitch that could be the culprit.
I had this same situation. The starter would engage and crank the motor but it sounded really bad and I was eating starters. Once I got the starter with the correct number of teeth for the flywheel it cranks and sounds like a new car
rktect69
May 26, 2010 08:31 PM
a-dusty-camaro
82-92 V8 Tech
May 12, 2009 10:05 PM
a-dusty-camaro
Mar 15, 2009 01:55 AM
1994z28
Nov 25, 2007 03:49 PM
Jaguar543
Oct 9, 2005 07:24 PM
