STALLS OUT AT LIGHT
Old May 12, 2006 | 10:04 PM
scottlarocco's Avatar
Default STALLS OUT AT LIGHT
I HAVE A 1967 CAMARO RS V8 327, IT STRTED STALLING OUT WHEN I COME TO A COMPLETE STOP. HAVE TO KEEP FOOT ON GAS TO KEEP IT RUNNING. SHORTENED UP THE ARM TO THE CARB, BUT RUNS RUFF. CAN ANYONE HELP?
Old May 12, 2006 | 10:21 PM
SickSickSick's Avatar
Default RE: STALLS OUT AT LIGHT
You Left Very Little Info ... Kinda Hard To Troubleshoot Stalls Without More Info. Stalls Like You Discribed Is Generally Because Of The Carb Loading Up. Bad Plugs, Wires, Rotor, Fuel Filter, Or Distributor Cap Can Also Cause Stalls. Loss Of Vacuum Can Cause Simular Problems. When Was The Last Time You Had A Tune Up? Is The Motor Stock? How Many Miles It Got On It? Does It Run Fine Otherwise?Sick
Old May 12, 2006 | 10:30 PM
65K MILES, NEW CARB, SPARK Was running great two days ago. Did run out of gas.
[IMG]local://upfiles/3233/1F36CF0937EF436F83062FDA7ACB8C6A.jpg[/IMG]
Old May 12, 2006 | 10:34 PM
Holley Carb? Sick
Old May 12, 2006 | 10:46 PM
yes
Old May 12, 2006 | 11:12 PM
Well This Is Probably A Good A Place To Start As Any. You Need To Put A Vacuum Gauge On Your Motor And Make Sure You Have Enough Vacuum For The Power Valve That's In The Carb. If I Had To Guess I Would say You probably Have A 6.5 power Valve. With That Size Power Valve You Must Have A Vacuum Of Atleast 12 In. mg Idling In Gear With The Brake On. If Your Vacuum Is Less The Power Valve Is Opening up And Loading The Carb. Therefore Causing It To Stall Out. When You Test Your Vacuum At Idle In Gear with The Brake On ... Whatever The Reading You Get ... Divide It By Two And Thats The Size Power Valve You Need. If You Read Lets Say 7 in. mg You Will Need A 3.5 Power Valve To Keep The carb From Loading Up. Since You Said This Just Started ... It Might Would Be A Good Idea To Look Over Your Vacuum Lines And Make sure One Isn't Disconnected Or Dry Rotted. If So ... That Will probably solve Your problem Without Power Valve Replacement. Sick
Old May 21, 2006 | 02:54 AM
MoreLikePALcohol's Avatar
Yeah check the vacuum on it. I had an 86 IROC with the same problem, used to have to pop it into neutral and keep reving it when I came to a stop...
ShOtzFiReD88
Jul 12, 2011 09:34 PM
drewscamaro
Feb 10, 2011 05:27 PM
AmirGTR
Mar 13, 2010 08:28 PM
1990z28tpi
82-92 V8 Tech
Feb 6, 2010 08:27 PM
gammohr
Jun 8, 2006 01:43 PM
