Speedometer cable question, electronic to mechanical?
It holds the cable into the transmission. If the tranny doesn't have that you'll need to find a adapter to cange the VSS signal to a rotational drive for the speedo. None of it has anything to do with the gauges.
I think what got thi confusion started is you were talking about your mechanical cable not working with the electronic speedo output on the trans. Then you showed us a pic of the cable end, and we thought you were showing us what you were talking about. Is there a reason the speedo end is off, or was it already off when you got it?
The speedo end on later 2nd gens is a clip held, while my '71 screws on to the speedo and the trans.
I may still be confused but, My car is a 76. Here is a pic of the back of my dash. My finger on the clip thing and my cable. I can't get to the tranny end of the cable now. It is a 350 and screws on.
Hope this helps
Hope this helps
I'm confused too now! You have a clip and threads? I don't see any threads anywhere on that speedo? Looks like it's a straight clip on to me?
