Reverse flow pump question
Old Feb 28, 2008 | 07:45 AM
Dark Dragon's Avatar
Default Reverse flow pump question
Does anyone make a reverse flow water pump for older blocks, say a 75 350? Would there be any benefit to putting one on a regular flow system? Thanks
Old Feb 28, 2008 | 10:27 AM
Default RE: Reverse flow pump question
Are you referring to a reverse rotational pump for a serpentine/idler setup? A serpentine setup makes the water pump rotate the opposite direction of a conventional v-belt setup. It will bolt to the block just like a regular one. But if used with a conventional belt setup, water won't flow through the system, and you'll have a catastrophic over-heating problem.
Old Feb 28, 2008 | 08:03 PM
JRs72RS's Avatar
February 2009 ROTM
If you are talking a system like on the LS engine, I don't know of any. There may be benefits if you could do it, but the plumbing would be a nightmare.
Theresa Fox Allen
Feb 9, 2015 12:38 PM
stan1277
Aug 4, 2010 06:47 PM
Vandee
Sep 22, 2009 10:07 PM
purpl96
Aug 17, 2007 06:17 PM
KingJames
Jan 20, 2006 06:14 PM
