Replaced transmission and B&M Shifter need advice shifter terrible
Old Oct 2, 2023 | 05:05 PM
Jonathan Welfeld's Avatar
Default Replaced transmission and B&M Shifter need advice shifter terrible
Have completely rebuilt a 79 Z28 hardest thing i have ever tried to do. Everything new with new shifter BMM 80694 Transmission shop installed and said it sucked
Got it home and had to shut it off in neutral
Any options for center console automatic replacement shifter
Everyone told me it was my only option it is also almost $500 and sucks
Any advice
Old Oct 2, 2023 | 06:21 PM
Hmmm,B&M has a reputation for quality gear,makes me wonder about the transmission shop that installed it.
Are you sure it was the right set up for your trans? Did you buy it and take it to them or did they order it?
Only option? I seriously doubt that,what trans do you have?
Old Oct 2, 2023 | 06:25 PM
Here's a rebuilt GM factory shifter on eBay: https://www.ebay.com/itm/16635904162...Bk9SR4CCoaveYg
Old Oct 4, 2023 | 08:01 AM
700R4 need a 4 speed shifter
Old Oct 4, 2023 | 08:05 AM
The one I replaced was also same BMM shifter
You had to be a Gorrila to shift it, thought it was just old but new one behaves the same trans shop very experienced
Need four speed shifter for 700 R4 trans
Any thoughts
Old Jan 3, 2024 | 06:48 PM
Dreamer's Avatar
Default B&M
Any thoughts
I have a Ratchet shifter in an 82 Ram pickup they can be used with 700R4 there's a tab of some kind that you need to remove. Also most of the time adjustments need to be made with the vehicle manually shifted to low. Then the cable tightend from there. But with mine I had to do it in park then ajust it. As far as operation once adjustments done it was dead nuts and smooth just the reverse lock could be annoying.
sgtdupree
Feb 2, 2011 07:59 AM
ble674
Mar 15, 2010 01:28 PM
brody
Sep 13, 2007 06:00 PM
hurley870
Mar 6, 2007 07:58 PM
Raven91Z28
Nov 30, 2006 03:21 AM
