Question with a v8 swap..
Old May 17, 2006 | 05:38 PM
mattvogt's Avatar
Default Question with a v8 swap..
I just put my 355 in 2 weeks ago, we are still hooking up all the stuff but I have questions about the wiring harness and the computer, What do I need to do with it? I dont want to replace it all if its possible. Let me know If I need a computer at all or if I can just take it out. Thanks for all the help guys. Hope to get responses.
Matt
Old May 17, 2006 | 08:12 PM
SickSickSick's Avatar
Default RE: Question with a v8 swap..
Assuming You Went Carb ... Stand Alone Distributor ... And A 350TH Tranny ... Its Now Nothing More Than Extra Weight. If Your Still Using A 700R-4 Tranny, Your Not Gonna Have Lockup Which Unless Your Worried About Gas Mileage You Don't Need It. The Lockup Option Won't Work Right Without Being Hooked To The Other ECM Components Anyways. A 700R-4 Tranny Works Fine Otherwise Without The ECM. Also ... If You Do Want Lockup You Can Run A Hotwire To The A-Terminal Splice C And D Together And It Will Lockup In 3rd Gear Or So I'm Told. I Race Mine Without A Lockup. Sick
Old May 18, 2006 | 08:36 AM
mattvogt's Avatar
thanks, I have a HEI stand alone distributer, a Th350 tranny, a 355 block with out any sensors (no o2 or anything) and its carbed with a holley 750.
Thanks for the great info.
What else did the computer run?
Matt
Old May 18, 2006 | 11:40 PM
Thats It ... Fuel Mixture , Ignition, And Tranny. You Can Probably Sell Your Computer And Harness For A Few Bucks, What Engine Was It Hooked To? Sick
Old May 24, 2006 | 05:19 PM
mattvogt's Avatar
it was a 231 v6, not a nice engine, also, I just wired up the alternator, distributer, and starter to one wiring harnes line and everything else seems useless. We will see if it works, when I turn the key the car cranks. so good so far.
9434V6
Sep 8, 2011 11:51 AM
pimp2303
82-92 V8 Tech
Aug 27, 2009 05:58 PM
VanHalen
Mar 3, 2009 05:10 PM
built383
Sep 22, 2008 10:03 AM
myohann
Aug 24, 2008 02:05 PM
