Question about a 1980 Z28
Old Nov 17, 2006 | 02:10 AM
nscfn8's Avatar
Default Question about a 1980 Z28
I was wondering what the best supercharger would be for a 1980 Z28 Camaro with a sb 350? Also, if anything else would be needed for me to put one in..Thanks
Old Nov 17, 2006 | 02:27 AM
94Z28SHAKER's Avatar
Default RE: Question about a 1980 Z28
try weiand or littlefield, you will need big exhaust at least 3", headers, valvetrain upgrade, fuel system upgrade/misc parts ect.
Old Nov 22, 2006 | 11:07 AM
mattvogt's Avatar
Im pretty sure that you need an engine built for boost. So you will need low compression and strong internals. Bad Idea to try it on your stock engine.
Old Nov 22, 2006 | 01:07 PM
shnormo's Avatar
Very true. Hypernumatic pistons, balanced pistons and rods, Aluminum H rods, 8-8.5:1 compression ratio. Larger cam, high flow fuel pump, better oil pump pick up, different valve springs.
http://store.summitracing.com/partde...5&autoview=sku
small diameter carbs, upgraded fuel pump and regulator and extensive tuning.
Old Nov 23, 2006 | 01:35 AM
GRIFF's Avatar
There is a lady who runs a vortech style supercharger in a street driven 4th gen at our local track it is very impressive and fits under a stock hood you cant ever tell its there. I have seen people put them on stock engines which sometimes results in problems but i think it matters how much boost you run an 80 350 is already low compression. The engine is what stock ..180 hp I wouldnt be afraid to push another 100 or so hp out of it. If it blows it gives you a good excuse for a dart block .
Old Dec 11, 2006 | 02:49 PM
nscfn8's Avatar
well i bought the car and the engine was already built up...me and my dad believe its around 350 hp..its not the stock engine so...thats y i wasnt sure what needed to be done..i know not to do it on the original engine lol
Old Dec 12, 2006 | 09:48 PM
hotrodguy1986's Avatar
you will also need some hood modifaction because that style camaro has little tono hood clearence i have a 77 that most chrome air cleaners won't even fit on
longshot362
Apr 2, 2014 03:14 PM
80Mike
Mar 12, 2012 11:22 PM
1980Z28RustBucket
Jul 6, 2010 10:43 PM
Jose20
Dec 9, 2009 11:00 PM
rpdalton
Apr 12, 2006 01:53 PM
