over rotating the key to crank ?!?
Old Aug 20, 2011 | 03:16 AM
EdPDX's Avatar
Default over rotating the key to crank ?!?
I was having problems in my 73, as it required muscle power to over-rotate the key to get it cranking.
I replaced the key cylinder; but it is the same turn with brute force past start and hope it cranks.
Has anyone had this happen?
Old Aug 20, 2011 | 07:16 AM
Haven't personally, but a friend did. It was the switch, not the key assembly. I think the switch was at the lower column, (near the floor) if I remember right.
Old Aug 20, 2011 | 08:35 AM
Makes sense what val said. Its an easy cheap fix too.
Old Aug 20, 2011 | 12:11 PM
You replaced the key cylinder, but the ignition switch adjustment is actually your issue. Yes, the switch is screwed to the top of the steering column, about halfway between the dash and firewall. When you turn the key forward to start, the lock mechanism pushes a metal rod forward (down the column) to operate the switch, and it appears the switch isn't being moved far enough. The switch has slotted mounting holes so that it can be adjusted. You need to slide it up a little, more towards the steering wheel, so that it hits the start position sooner. Don't go too far, and re-check the other key positions to make sure they still work in the correct spot.
Old Aug 20, 2011 | 12:24 PM
LOL I had the one in my 78 stick in the on position. As soon as I hooked up the battery, vroom!!!
Old Aug 20, 2011 | 12:30 PM
Ooooops!!! Hate when that happens.
Old Aug 20, 2011 | 05:31 PM
Learned a lot that summer.
NorthernCrew454
Aug 6, 2013 07:27 AM
NorthernCrew454
Jun 4, 2011 06:08 PM
NorthernCrew454
May 1, 2011 09:35 PM
wicked94z28
Feb 7, 2011 12:19 AM
microkid
Feb 22, 2007 12:13 AM
