Need a little help - alternator mounting
I need a little help on where to find a new mounting bracket system for my alternator. I just picked up a nice set of ported camel hump heads that have no provision for the accessory mounting. My AC is Vintage Air and it came with compressor mounts that don't use head boss mounting locations. I've looked on Summit but can't find a mount for the alternator on the passenger side that is definitely made to mount an alternator without a threaded hole. Does anyone know of a mount and where I can get one? Thanks!
Here's the pieces: Around $25 for all three pieces.
SUM-G4049
SUM-G4050
SUM-G4051
Thanks Val, I checked those and if I had the short water pump they'd be perfect but I don't. I can't find one that will work with the long pump....yet. I should have stated that I had the long water pump. The search goes on.
Looks like I solved my own problem. I checked the March Performance catalog and found that they have an adapter bracket that lets you use one of their kits that use the hole in the head. A bit more expensive but then they make a good product. Thanks Val. Your post made me go back and look harder.
Just entered "summit long water pump alternator bracket" and this came up:
http://www.summitracing.com/parts/MCH-20122-09/
http://www.summitracing.com/parts/MCH-20128-09/
