Need help with carb
Old 03-02-2014 | 07:45 PM
Jonathon Thomas's Avatar
Default Need help with carb
So the carb on my 79 Berlinetta needed a cleaning and rebuilding, so I bought the only kit I found for a reasonable price online and when it got here it didn't fit. I then found a Rochester DualJet that my research said should fit, and it didn't. Can someone help me find the right rebuild kit for my stock carb or a replacement carb that will fit the engine? Or at least tell me the model numbers I need.
Old 03-03-2014 | 10:33 AM
Everett#2390's Avatar
Two items for you to find:
1. a stamped metal tag attached to one of the bowl screws - use this number for parts,
2. on the drvr side above the throttle shaft, is a stamped number - carburetor code - tells the year and application.
Surprised the kit did not fit, generally, there is extra gaskets and things for universal fit through the years.
Old 03-09-2014 | 01:55 PM
So the part number I just found on there and looked up matches a 74 Chevy. The picture matches, but I can't figure out why I would have this carb on my car...
carguylt1
03-28-2011 10:30 AM
white85camaro
07-29-2010 05:16 PM
cadfleet
07-06-2010 10:28 PM
albo1989
82-92 V8 Tech
07-01-2010 07:40 PM
Gordon24Camaro
01-11-2007 10:46 PM
Quick Reply: Need help with carb
