need help with an 81 camaro
Old Sep 27, 2006 | 10:57 PM
gcm215's Avatar
Default need help with an 81 camaro
i have an 81 350 z28 camaro that i just got for my first car and i was wondering what can i do to boost the hp on a small budget since i couldnt afford a nicer one i just thought i could beef it up but im not exactly sure where to start and i was just wondering if anyone on here has any imut on the subject
Old Sep 27, 2006 | 11:46 PM
1969 SS's Avatar
Default RE: need help with an 81 camaro
budget?
intake, ignition and exhaust. that's the cheapest and easiest bang for the buck. you don't have to tear the engine down and they will still work on a new build if you get money down the road to get a new one
Old Sep 28, 2006 | 11:10 PM
gcm215's Avatar
yeh somthing like 1000-1500for the budget not trying to spend to much money you know cuz im gonna need to put gas in the car since it doesnt seem to be great on gas also any brands or **** in particular im kinda new to this so you know
Old Sep 29, 2006 | 01:38 PM
1969 SS's Avatar
you can definitely do that stuff on that budget. MSD is the best ignition, you will need a distributor, a box (preferably their 6AL because it has a rev limiter) and a coil (Blaster 2). you could go with a Holley 650 with Vacuum secondarys and an electric choke (Holleys are the easiest to adjust) and just look for a decent header but remember that if you go the cheapest route, you will DEFINITELY get the cheapest quality. the biggest thing to look for with headers is the thickness of the flange where it bolts up to the block. the thinner it is here, the more apt it is to warp and cause leaks. I always use Hooker
these are all just my opinions of whats best, but opinions are like a**holes, everybody has one
Old Sep 29, 2006 | 02:16 PM
aj69z28's Avatar
i would start with exhaust. headers, large tubing, low restriction mufflers. it will increase hp, and it just sounds good!
Old Sep 29, 2006 | 02:54 PM
74454bb's Avatar
May 2007 ROTM
I would start off with an Edelbrock intake, Holly -or- Demon 650 carb, Hooker headers, And a Accel or MSD HEI ignition. And top it off with a K&N filter and Magna Flow exh. This should be within your spending limit and still have some left to play with.
Old Sep 29, 2006 | 08:08 PM
SickSickSick's Avatar
holley 600 cfm vs, weiand stealth high rise intake, .480 lift .300 duration cam, summit headers ... approx. 75 to 100 hp ... approx. $700 bucks including gaskets and lifters. for another $200 msd pro-billet stand-alone distributor. can be upgraded to a box when needed. Sick
