motor swap
Old Aug 17, 2008 | 06:56 AM
BIG.D's Avatar
Default motor swap
I'm gettin a 79 camaro with a 305 in it and want to put a 350 in it. Whatwill i have to replace??
Old Aug 17, 2008 | 02:10 PM
73camaroSS's Avatar
Default RE: motor swap
the motor just about every thing else is the same for a 305 to 350.
Old Aug 17, 2008 | 05:46 PM
BIG.D's Avatar
Thanks, i just wanted to make sure because i know other places i read they say when switching motors you have to replace pretty much everything. I think that may of been switching from a v6 to a v8 but basically i justdrop the 350 in and everything else will work without any problems?
Old Aug 17, 2008 | 10:03 PM
screamineagle's Avatar
Exactly right. Even if you want you can swap heads,crank,intake,rods etc. They are exactly the same just the bore is different size. Thats the joys of a chevy. ford evenhas 2different firing orders on the 302 you cant mix an match anything really. Chevy small block to big block isn't much headers,some other ods and ends and your set.
Old Aug 17, 2008 | 10:36 PM
BIG.D's Avatar
Thanks for the clarifaction guys!
Old Aug 29, 2008 | 10:44 PM
BIG.D's Avatar
Now i cant decide what i should do. The engine thats in my 79 camaro is the original so its 29 years old but i cant decide if i should put a 350 in it or just build up the 305. Whats your guys opinions on this?
Old Aug 30, 2008 | 11:26 PM
thebandit110's Avatar
350...dont waste your time with the 305 unless you want an all original car....but these 2nd gens are worth more modified than orignial....in most cases.
Old Aug 31, 2008 | 07:38 AM
BIG.D's Avatar
What will be the difference in gas mileage between the 305 and the 350?
riverman95-99
Feb 12, 2012 01:59 PM
sandvipr
Apr 25, 2011 12:03 PM
mregulater
82-92 V8 Tech
Mar 10, 2009 11:47 AM
dmolaver15
82-92 V8 Tech
Dec 20, 2008 08:46 PM
Camroman250
Apr 30, 2006 12:17 PM
