It Lives...Here Starts the Project
#41
I've actually been contemplating selling the street bke as it sits so much, but hate to let it go after having it for alomost 20 yrs!
#42
I located my leak...kind of...It looks like it originates just above the lowest motor mount bolt on the block. I know there's a freeze plug located above the bolt.
It leaks under pressure, and when there's no pressure (engine cooled off for 2 hours) and still dripping.
There was lot's of smoke today when I fired it up after dyeing the antifreeze and filling up the radiator but it didn't smell like burning antifreeze.
What are the chances that it is just a freeze plug that just rusted through? I'm praying that's all it is.
#44
Unfortunately I agree. It's in the nature of the 400 siamesed block to have issues between the center two cylinders with overheating and possibly cracking. Hope it's just a freeze plug, but you'll have to pull the engine to be sure one way or the other.
#45
The water is not coming from the head. I'm sure of that. It's originating around the lowest motor mount hole. I won't know for sure until I rip it out...hopefully in the next day or two. My parter in mechanical crime's tranny just took a dump on him...up in Ohio, so his will get priority, once it get's down here, it's his dd.
On another note, (just in case my block's FUBAR'D), how much trouble would it be for me to bolt an M 20 up to a '90chevy block? I found a complete/unmolested 5.7 from a truck for $100. I'll have to rebuild it of course, but it sounds like a good start if my block is screwed.
#47
On the rearend it should be a drop in. I changed to a 79 T/A rear axle in my 71 and the only thing I had to change was the cables for the emergency brake. I think in your case you wont change anything from a '77 to a '78. That's a great deal on a posi with that gear ratio!
#48
Finally got to spend some quality time with Marti today.
1030am![Name: 10-20-2009148.jpg
Size: 195.6 KB](https://camaroforums.com/forum/attachments/70-81-general-12/35639d1501323570-lives-here-starts-project-10-20-2009148.jpg)
5:00pm (roughly)
![Name: 10-20-2009150.jpg
Size: 181.5 KB](https://camaroforums.com/forum/attachments/70-81-general-12/35640d1501323570-lives-here-starts-project-10-20-2009150.jpg)
Then it started raining on me, so I had to stop.
More to follow tomorrow...Before and afters of the engine bay and what i find in the motor.
1030am
5:00pm (roughly)
#49
I see some discoloration between #5 and #7 cylinders running down the side of the block? Either from around the dipstick tube, or from the head? Anything to do with the water leak?
Or was it the sending unit up there between #1 and #3?
#50
You're an observant fellow! I had to look at the pic twice, then go pull the plastic off the motor, to see what you were talking about. lol! GOOD EYE
![Icon Wink](https://camaroforums.com/forum/images/smilies/icon_wink.gif)
As I take the motor apart tomorrow, I'll post pics...lots of pics...I want opinions...everybody's.
Then we'll figure out how to build her!
On another note...you 1971BB427 and Camaro69 should write a book (or an interactive webpage )on camaro's. You guys rock!
