Ignition lock change help
Old Feb 8, 2007 | 07:24 PM
NightWolf's Avatar
Default Ignition lock change help
Ok heres my situation im changing my lock cylinder.Now i took the steering wheel and lock plate and then the turn signal switch so im at the part where im supose to find the spring to release the cylinder. Now i realy need help finding where it is i tryed looking it up but got vauge answers and didnt realy help so if someone could help me with this even a diagram would be great casue i need to change this cylinder fast. I have a 1981 camaro.
Old Feb 8, 2007 | 09:32 PM
NightWolf's Avatar
Default RE: Ignition lock change help
Ok I got a picture of where I am so if someone can show me what to do next to get that cylinder out.I just need to be pointed in the right spot, u can even jsut copy the picture and edit it with paint or something and post it. I realy need the help.
[IMG]local://upfiles/6441/4E91109BF0A94B9887C9FB482318B71A.jpg[/IMG]
Old Feb 8, 2007 | 10:56 PM
79maroman's Avatar
see that plastic tab with two copper tangs coming off of it.(at the 3 o'clock position) you need to pop that plastic part out(the tangs are connected to it so they come too.
once you have that out, take out the dark colored phillips head screw. that screw holds the cylinder in and you will be able to slide the cylinder out.
i hope this helps
Old Feb 9, 2007 | 12:37 AM
NightWolf's Avatar
Lol thanks man i got it and its all good now I love this forum! Im glade theres a good place to go to when I need help or advise
Old Feb 9, 2007 | 12:51 AM
79maroman's Avatar
no problem, i'm glad i could help.
1977Camaro350
Apr 19, 2010 04:55 PM
tj89rs
82-92 V6 Tech
Mar 8, 2010 08:14 PM
typeomang
Mar 24, 2008 12:07 AM
Beninarkansas
Nov 13, 2006 11:09 AM
cam.chris
Feb 21, 2006 01:32 PM
