I need HELP! Transmission
Old Apr 18, 2010 | 03:33 PM
nmeeks20's Avatar
Default I need HELP! Transmission
1980 camaro 355 turbo 350
Stopped at a stop sign yesterday and went to move and couldnt go anywhere. I never heard any clangs, checked the transfluid. I also changed out the modulator valve still not working. Im thinking maybe the torque converter, any ideas?
Old Apr 18, 2010 | 03:41 PM
Possibly converter, possibly clutches. Might be an obstruction in the valve body. Tough to say, but it will most likely need to be opened up. You might try changing the fluid and filter, then you can check in the pan to see what's floating in there. If it's got lots of metallic color it's probably worn out clutches.
Old Apr 18, 2010 | 05:14 PM
rosky69's Avatar
1^+. Definitely change your fluid and filter first. I had the same thing happen to me in my 77 blazer several years ago. I changed my fluid and filter (after a transmission shop told me I needed a rebuild), and everything was fine. Try that first!
Old Apr 20, 2010 | 09:53 PM
nmeeks20's Avatar
thanks guys! Unfortunately I changed the filter and that didnt fix it so Im moving on to the converter.
Inked88
Jul 27, 2011 10:57 AM
dsinclair999
Feb 21, 2011 11:24 AM
randolphdelpriore
Jul 4, 2008 11:05 PM
DeputyDog
May 22, 2008 02:45 PM
camaro girl
Apr 8, 2007 04:58 PM
