camaro z28
Old Apr 12, 2010 | 03:31 PM
mjb13090's Avatar
Default camaro z28
im removing the motor and trans from a 80 camaro. how many bolts consist of removing both motor and trans. also do i have to keep all of the old smog stuff. i am completely rebuilding the motor without all that stuff. thanks for the help.
Old Apr 12, 2010 | 07:54 PM
Welcome to the forum!
You need to pull one motor mount bolt from each side of the engine, then two bolts from the trans, and 4 bolts from the trans crossmember. Then whatever bolts from the exhaust depending on whther you leave manifolds on the engine, or split them at the exhaust pipe.
Then there's all the electrical, starter wires, pull battery leads, and misc hoses, etc.
Just keep pulling stuff 'til she comes out!
Old Apr 12, 2010 | 08:05 PM
ATM's Avatar
ATM
As for keeping the smog stuff, you just may be able to sell it to someone doing a restoration.
Old Apr 12, 2010 | 08:33 PM
mjb13090's Avatar
thanks will do that. ill keep everyone posted.
Old Apr 21, 2010 | 04:54 PM
mjb13090's Avatar
were are the two bolts on the trans located. i got the 4 bolts from the cross member. i dont know the other two.
Old Apr 21, 2010 | 04:57 PM
ATM's Avatar
ATM
The four bolts on the crossmember bolt the crossmember to the frame. The two bolts from the trans bolt the trans to the crossmember, it may be covered in muck.
