I need help with my defroster please.
Old Jan 10, 2012 | 04:10 PM
bmorrow's Avatar
Default I need help with my defroster please.
My defroster will not defog my front windshield. I have no idea why. Its blows very hot air and it also blows cold air. I put more freeon in it but that didn't help. Thanks in advanced
Brennan
Old Jan 10, 2012 | 04:34 PM
Does it blow hot air out the defroster vents, or out the heat vents? It may be that the hoses, or actuators aren't working to get that heat out the defroster vents.
Old Jan 10, 2012 | 09:06 PM
bmorrow's Avatar
it blows hot air out of the defrost vent.
Old Jan 10, 2012 | 09:20 PM
I'd guess the problem is restricted flow then. Most likely either the cable that direct heat to the vents is out of adjustment, or the door that's inside the heater box is disconnect, broken, etc. and not directing full volume to the vents.
I did see one a friend has where a mouse had built a nest in the vent hoses and plugged up flow to the defroster vents. I'd pull the vents off the box and blow through with an air hose. Then run heater defrost with the hose off and see if there's good flow out the heater box.
Might also check the fan switch to see if it has all three speeds.
Old Jan 10, 2012 | 09:29 PM
bmorrow's Avatar
thanks! that helps alot. i can always count on you haha
Old Jan 10, 2012 | 09:54 PM
Shalamara's Avatar
March 2013 ROTM
If your 80 is vacuum controled like my 78, as much of a pain as it is run down all your vacuum lines for the actuators and make sure they are all in tacked. I had one broken line that caused me a lot of problems.
Old Jan 11, 2012 | 09:30 PM
bmorrow's Avatar
well i think i found the problem today. i pulled the carpet up a little and under the passenger side dash is pretty wet. heater box must be bad. how hard is that?
Old Jan 11, 2012 | 09:55 PM
Heater box is a bit of a booger. It will involve a day's work to pull the box, as you need to pull the inner fenderwell to get to all the bolts and get the outter box off too. If the inner box is wet it could be a rusted out box, or a bad heater core. Either way I'd replace the core while the box is off.
Most likely you'll have to have the box welded up, unless you can find a solid used one.
Kubs
Jan 4, 2012 11:05 AM
MelloYello
Dec 1, 2010 03:43 PM
RAJ484
Aug 27, 2010 07:01 PM
cedwards
Aug 7, 2009 11:37 PM
Van Buren
Jan 5, 2008 06:02 AM
