I have a 81 camaro and i need to know what engine i have in it.
Old Oct 6, 2008 | 07:47 PM
guest7's Avatar
Default I have a 81 camaro and i need to know what engine i have in it.
It originally came with a 305 according to the title however i do not think its the original motor. Only numbers i seen on motor were 18436572 Can anyone figure it out just by those numbers? I have people telling me its a 305 and others saying a 350!? Im thinking its a 305 personally.
Old Oct 6, 2008 | 07:48 PM
guest7's Avatar
Default RE: I have a 81 camaro and i need to know what engine i have in it.
Also if u cannot tell by those numbers where would i find the right numbers for you to be able to find out?
Old Oct 6, 2008 | 09:19 PM
You found those numbers on the intake manifold, and they are your engines firing order.
Look on the block, drivers side near the bellhousing for the casting #. That will tell you what the engine might be. Near the casting #, or in the same place on the passenger side will be the date code. And the numbers stamped on a pad in front of the passenger side head will tell the rest.
http://www.chevy-camaro.com/chevy-ca...oding-help.asp
Mony Montana
Jan 10, 2013 03:04 PM
ThisGuy68
Jun 20, 2010 02:39 PM
solei
Jun 13, 2009 08:06 PM
zerokool91
May 24, 2008 07:21 AM
Lifted07Sierra
Feb 24, 2008 12:03 PM
