Hp guess
Old 10-01-2013, 09:44 AM
Easy way to figure out if the mechanical fan is holding you back! When you get to the track just pull the fan and replace the bolts so you still have the pulley and everything working. You'll run a little warmer, but for a few runs with cooling in between it wont overheat. It will tell you immediately if the fans can help your HP, but remember the electric fans will add current draw to your alternator, so that will also try to slow down your engine a tiny bit.
I'd wait until I had the slicks and the new converter before I got anxious about changing anything else. I like to do one thing at a time, but these two would go well together, and I'd do both if possible, but not add others at the same time. Too many changes at once, and you wont learn which was the most beneficial to your goal.
  #52
Old 10-01-2013, 09:50 AM
Cheeks's Avatar
August 2011 ROTM
your mph will be higher if you spin then when you hook. When you get some good tires and a decent stall in it, you'll see your ET and mph drop.
Generally, picking up 5mph at your power level will take about 100whp. A small shot of nitrous would do it just fine.
  #53
Old 10-01-2013, 11:40 AM
Flextrainer's Avatar
Thanks guys. Precisely the info i needed. Thanks for not beating me up either. I have just been out for ten years and you lose info. I have theories i use, but you have the real world experience. I usually do one at a time, but like you said i get anxious more than i should and only few more weeks of good racing left. Will hang it up for year i believe it is gonna run what it does without a major change, not just tweaking. Thanks again guys i value your input.
  #54
Old 10-30-2013, 12:14 PM
Drove it over 500 miles this past weekend and ran 7.50's driving it. so streetability is an invalid point. outran a zl1 and yea he was trying. His best was an 8.0 1 mph slower. He made several passes. And before you go there i was running street tires too with a 1.7 60'. All motor no power adders. Had to add weight(tool box& full tank) and pull power (pedaling) to get 60' to there.so I will get you some 7 teen slips this spring. Wont touch motor just suspension, stall and slicks. Just getting the info you asked for. Don't need a dyno with weight et and mph. I will give you that I am a great driver, but I'm still not getting it all down. That has to be more than 400 crank hp. Right? Isn't that how cars are rated from factory? Crank hp. I am not trying to be smart but i know this is more than 400 hp, i cant be that good of a driver. I also know I am losing 15-20% through slush box. I think the numbers are as good as a dyno for proof here. Highest trap speed to date 97(with race gas) Never weighed with full tank, but with less than qtr 3659.
  #55
Old 02-25-2014, 11:09 PM
Thanks.
  #56
Old 02-26-2014, 03:39 PM
Cheeks's Avatar
August 2011 ROTM
you still aren't making 500hp, not even with a .40s pass.
I'm probably heavier then you (3030 race weight) and run a 6.60 off the footbrake on motor with a tight nitrous converter and I make in the 573whp, through a th400 and a 9 inch. That's with a 1.7 60ft to show you how tight the converter really is
  #57
Old 02-26-2014, 06:04 PM
Lol I already knew that cheeks or I believe you as you have posted no slips of yours in profile(did notice the nice even numbers though, don't see that much at the track, also noticed your claim of 1.42 60' not 1.7). Wasnt talking about you, you ended up being a help. I weighed on scales at 3659 (just a tad more at 600+lbs extra)with no ballast and 1/8 tank. Add 75 and about 9 gallons to that for weight that day(traction=et, extra weight =less mph).
I posted slips with 94, 95, 97, with slower et too. So I have not put anything that is not verifiable. Track was crossville 1900' 85-90% hum. 65*Date and track on slip, weather can be checked online. Altitude by wikipedia or other source. Weight was only 3659 that day. Just use 7.98 for et and 95 for mph. Slip in this thread or my other one.
It is a full weight street car not a drag car. If that ain't 500 at the crank( I did after all post build sheet not car, so I don't know why whp keeps being brought up as that was never mentioned in my post. Motor makes the power not the car hell the motor's liable to be in a 2700lb roller next week, doubtful till I get the 434 done, but possible) I'd hate to think what I could do with 500 once I can put it all down, that's all I can say I don't need your validation any way. Wallace racing calculators are known for being accurate and I don't know you although you have proven to be a good source. There are many others that can be used but this one is well known.
Calculate HP with HP Correction from 1/8th ET- Wallace Racing
7.40's heck I had that before all this work not that et is even part of the discussion as it only tells suspension not power. I think yall are missing that point im not getting it all down so adding weight and pedaling is the exact same thing as saying pulling power.That's all I can say till next month about that.
  #58
Old 02-26-2014, 06:08 PM
Here's a good read.
1) Trap Speed will tell you about your HP to weight.
2) ET will tell you more about traction and your launch.
Of course ET is important to true drag racers, because the winner is the one that gets there first. However, we're not necessarily true drag racers in our attempt to get a power estimate. Honestly, ask 10 guys at the track "What kind of trap speed are you running?" and 8 out of 10 will answer with their ET - to one or two decimal places even. When you say, "No, no, I meant trap speed", they will fumble with a broad estimate with NO decimal places and might even have to pull a time slip out of their pocket to check. Try this question when you're at the track; it's almost funny.
THE DYNAMICS OF TRAP SPEED VS. ET
After running lots of quarter miles, it becomes clear that how well you do in the first 100 feet of the track is KEY to a good time. The last half of the track is KEY to a good speed.
Let's use an example of a stick-shift mini-pickup that on a perfect run, gets a timeslip of 19.50 seconds at 70.00 mph in the quarter.
Imagine that the light turns green, the truck moves two feet and the engine dies for three seconds. After restarting the engine, the driver proceeds to then complete a perfect pass. His time slip would show 22.50 seconds at 69.97 mph. The ET was 3.00 seconds high but the speed was almost unaffected.. why?? It's because his racetrack was 1318 feet long instead of 1320, and in those last two feet this truck usually gains an additional 0.03 mph. However, the clocks recorded the long time. My point? Much of a great ET is made by a great launch.
Now take this truck again, and the driver leaves right on the green light. However, he misses the 3-4 shift when he's at 1250 feet. He coasts for the last 70 feet while trying to find fourth gear. Now instead of accelerating another few mph in this final 70 feet of the track, he decelerates over this distance. His timeslip; 19.51 at 67.83 mph. Note how the et is almost perfect (only off by 0.01 second) but the trap speed is way off (over 2 mph slow)! On a good run, traveling that last 70 feet at an average of 69 mph, would have taken .692 seconds. At a 68 mph avg., that 70 feet takes .682 seconds. That's why his ET only varied by .01 seconds, yet the trap speed was 'way off'. My point here: the end of the track is critical to trap speed; shift rpm, missing a gear... these are the big players.
Hopefully these examples are clear. Neither of these runs are 'perfect' runs, it's just that one has an error at the start, one at the finish and the results are obvious. The start of the track is a big player in the ET, but a small player in the mph. The end of the track is a big player in the mph, but a small player the ET.
So for the casual T-Bricks member who wants to get a HP value, you don't have to buy slicks, or wish you had a limited slip differential. You don't really need to heat the tires in the waterbox, or launch with huge power braking. As long as people get their shift rpm right and don't miss a gear, even a rookie will get the appropriate trap speed for their vehicle.. but honing the perfect ET. requires being rude to a clutch, buying steeper gears or slicks.... hey, we're trying to make this recreational.
OPTIMIZING SPEED
If your goal is to get a good trap speed, what are your options? More power, of course - and less weight is obvious (but it will come out in the power calculations as no increase in power). Shift rpm chosen (auto or manual) and the time it takes you to shift (with a manual) are probably the most important tools you've got. Try different shift points to maximize your trap speed. Reduce rolling resistance by pumping up all tires to their rated pressure. Some people think that running lower pressure might help the traction in the rear, though. Of course more traction will help et, but with most street tires, running street tires within 5 psi of rated pressure will provide you with maximum traction in the first place.
REACTION TIME
The ET clocks don't start until you've actually moved around 8 inches (this is called the rollout)... so don't worry about trying to leave right on the green light. You could wait 5 seconds after the light turned green, and still get a 19.50 timeslip in our truck example above. Your timeslip does show a separate calculated time, the "Reaction Time", which in this case would be 5 seconds. That is the time from the light turning green until you rolled out of the starting zone. It's not a big thing for our discussion here.
THE LAUNCH
For the most part, a decrease in ET is accompanied by an increase in trap speed, but don't go overboard on the launch in your zest to rule the world. Just try to get smartly underway without spinning the tires much at all. Traction levels usually drop a solid 0.10 g when the tires start spinning.
THE HP FORMULA
Here's the formula to use to calculate HP:
Net HP = Weight in pounds* (Speed in MPH/228.4)^3
As an example, Car & Driver tested the 744 Turbo in their June 1990 issue. The car weighed 3,081 lb. without the driver.. the 'race weight' was 3,231 lb. The car ran a 15.7 second quarter at 86 mph. Let's plug it in to the formula:
HP = 3231 * (86/228.4)^3
HP = 172 Net
Volvo rated this at 162 Net. We come out a little high. Or does Volvo underrate a little? I'll say this - I've used this formula for years and that's how the 228.4 was honed - actual experience from cars that had actual power curves - and when I use it on Volvos it tends to always come out a few percent higher than the factory rating. This could simply be that Volvo underrates just a little.
Still, for such a simple formula and such a simple test, it's surprising how accurate this can be. And the best thing is - there's no arguing the numbers on a timeslip. There are always differences between a DynoJet and an Eddy Current Dyno, or G-Tech numbers, but every setup is done by someone different and subject to error. The quarter mile is arguably the best comparison a diversely located group like Turbobricks will ever have. The only real difference to argue about is the altitude of the track! You can compare ET and mph all day and have a good discussion.
HANDY RULE OF THUMB
Once you have a baseline, you should probably use a rule of thumb that each additional 6 HP will give you another mph. That's for a 3200 lb car that runs 88 mph. If you want the real formula for different weights or speeds, here it is:
HP for another mph above "X" speed: = Wt * (((X+1)^3-X^3) / (228.4^3))
For instance a 89 mph quarter vs. an 88 mph quarter for a 3200 lb car:
HP delta = 3200 * ((89^3-88^3) / 228.4^3))
HP delta = 6.3 HP
Once you're going 110 in the quarter, it would take an additional 10 HP to go 111 mph in the 3200 lb car.
60 FOOT TIME
This is the standard measurement tool to evaluate your launch. It's the time that it took you to travel the first 60 feet of the track. Naturally, patterns emerge again after looking at lots of runs and of course these correlate best to time, not mph. Typically, most everyone's 60' time will be between 14% and 16% of their quarter mile time. If it's under 13% or over 17%, this was not your best pass.
1/8 MILE VS. 1/4 MILE
After monitoring tons of good passes, patterns emerge. Typically, the mph at the quarter is around 1.26 times of the mph at the eighth, and the time at the quarter is around 1.55 times the time at the eighth. You can use these values if you only have a 1/8 mile track and get a real good idea of the theoretical 1/4 mile.
IS MY ET TO SPEED RATIO REASONABLE?
One fact of the quarter mile is; no matter how slow or fast your car is, the mph multiplied by the ET will pretty much be the same number every time. Before the NHRA changed the way that speed is measured in 1989, the product of speed and time was around 1400. Let's calculate some easy examples of this. A 14.00 et usually resulted in a trap speed very near 100 mph. A 10.00 et meant around 140 mph. A 200 mph pass usually takes around 7.00 seconds. These are still good rules of thumb to remember, but now the product is more like 1380 for us - The example from Car and Driver above comes out at 1350. (The reason for this shift is explained below). Remember, most everyone focuses on ET so much that they'll even optimize a car for slower mph if it gets them a better ET. (Rear end gearing is one way to do this). Those guys tend to have a product closer to 1300.
RESPECT MORE SPEED - A LOT. EVEN 3 MPH.
If you look at the formula again, you'll note how trap speed shows up as the cube root of power to weight. That's critical to understanding how fast one car is over another. Let's say your car does a 90 mph quarter and the guy who raced you in the other lane ran 71 mph. After the race, he wanders over to you to say the 'race was close'. Your reply: "I could have towed you and still smote you". (This might not be the best way to make friends, but yes, it is TRUE if the cars weigh the same.)
Do the math. (90/71) cubed is 2.04. Yes, the 90 mph car has 2.04 times the power to weight of the slower car. It has 2.04 times the acceleration of the slower car. It's just that the track is a fixed length, and in accelerating to higher speeds, you use up the track quicker. You accelerated to 90 in about 20% less time than he had to accelerate to 71, right?
Bottom line; Down where most of us run, a 3 mph difference between two cars is NOT a race. It was a clear win. There's a full 10% difference between these cars.
SOME MAGAZINES SHOW THE CONSTANT AS 230.5 OR 234.0. WHERE DID YOU GET 228.4?
Some people try to correct to different things. Like Gross HP instead of Net. But most commonly, these other constants that you'll see in magazines were originally published before 1989 when the NHRA changed their lights, and the 'new' journalist doesn't realize the formula should change accordingly. Here's what I mean; previous to 1989, there were three timing lights at the end of the track; one AT the end of the quarter mile, and one 66 feet before, and one 66 feet after. The middle light was used to calculate the et of the run, and the time to travel the 132 feet at the end of the track was used to calculate the trap speed. This gave the average speed at the end of the track, but you can see what this lead to. Most of the racers stayed on the gas for an additional 66 feet past the quarter to get a consistent speed to evaluate their setup. The track's 'shut down area' of course is a fixed length, but the pro racers were starting to hit 300 mph plus by the end. In an attempt to get these guys off the gas 66 feet earlier and 'make' the cars appear slower, the NHRA stopped using the last light around August of 1989. Today, the trap speed is calculated between the light at the quarter mile and the one 66 feet before. So any timeslip after 1989 is really giving the average speed 33 feet from the finish, which is pretty close to one percent slower than before. The old constant of 230.5 became 228.4 to compensate.
CORRECTING FOR ALTITUDE
If we were dealing with non-turbo cars, this would be easy and we'd publish a formula. But with pressurized cars, the correction factor for altitude depends on the boost you run.
For instance, Sea Level air pressure is 14.7 psi. If you go to a track in Boise, Idaho (2850 feet above sea level) the air pressure is now around 13.25 psi. That's 90.1% of sea level pressure. If the temperature doesn't change and you have an normally aspirated car, your power output will now be 90.1% of what it used to be, so I'd tell you to correct by multiplying your calculated HP by an extra 10.9% (1/.901, or 1.109).
However, (and this is the beauty of turbo cars!!) Let's say you were running 10 psi of boost in the first place. So at sea level, your car was really getting 24.7 psi (14.7 + 10). Now you leave the wastegate at 10 psi and race at Boise. Your manifold pressure is now 23.25 psi (13.25 + 10). Note that YOUR power isn't down as much.. it's down to 94.1% of what it is at sea level. So you should correct with an extra 6.2% (1/.941, or 1.062).
If you wish to calculate your own correction factor, here is a handy table of elevation (feet above sea level) vs. standard day atmospheric pressure (psi):
0 14.70
500 14.43
1000 14.18
1500 13.92
2000 13.67
2500 13.42
3000 13.17
3500 12.92
4000 12.69
4500 12.45
5000 12.23
5500 12.00
6000 11.78
6500 11.56
7000 11.34
7500 11.13
8000 10.91
8500 10.71
9000 10.51
9500 10.30
10000 10.11
Yes, the detail oriented will notice that I'm ignoring lots of small effects of higher pressure ratios in the compressor, lower density air across the intercooler and even the fact that there's less wind drag at higher altitudes, and they're right. However, the overall concepts above still hold true.
There's lots of discussion of 300, 400, even 450 HP on the Tubrobricks list. It would be great to see these power levels turn out to be true. Just keep in mind that an honest 300 Net HP in a 3200 lb Volvo (includes driver) will go just under 104 mph in the quarter. 400 HP would push it 114 mph, and 450 HP should propel the car to a trap speed of nearly 119 mph at Sea Level!
In terms of the ZO6, that makes for 19% less power at 5500' ASL (typical denver, there's a reason it's called the mile high city), so instead of 405 hp, they're making closer to 328 bhp.
If anyone else argues the point of how turbo cars are less affected by elevation than N/A cars without reading the exhausting long quote above, you are not only lazy... but an idiot as well.[/QUOTE]
  #59
Old 02-27-2014, 10:02 AM
I think it's best to wait and see the numbers. All this theoretical guesstimating can be close, but there are variables we've all discovered that can make the math change drastically. The best calculators out there are often found to be off due to some unknowns in the car's drivetrain. No reason to start, or continue a argument on it, as the actual numbers will eventually show the truth.
  #60
Old 02-27-2014, 10:21 AM
You're right and cheeks is a cool guy, kinda felt bad about my last post but I didn't mean it the way it came out. What I should have said is I'm not doubting him, but people that have seen it weighed and run seem to think so. I have never made the claim bc you are right only the numbers will tell. I'm only going off the calculators which btw all had me between 490-517 at crank based off my stats and still not considering traction and driving like you also said. I will not mention it again as it really does not matter, but I will let ya know how Bristol goes.
Quick Reply: Hp guess
