How Do I Aim my headlights on a 79
Old Jun 14, 2010 | 05:10 PM
Lj2069's Avatar
Default How Do I Aim my headlights on a 79
I just purchased my 79 camaro and the headlights are basically facing the ground. how do i aim them upward?
Old Jun 15, 2010 | 01:54 PM
Welcome!
If the buckets are all in good shape and not loose or bent, then it's simply raising the point of aim by the adjusting screws. There's a screw directly above each light, and one to the outside edge.
Park your car on a flat surface about 20' away from a wall or garage door. Measure from the ground to the center of your headlight, then put a tape mark on the wall at the same height. Now turn on your lights and screw the top screw clockwise until the center of the beam is slightly lower than the tape mark. That should do it.
If you run out of adjustment before it reaches the mark you've got issues with your buckets. If you need to move them left or right you turn the side screws accordingly.
If the headlights were installed correctly the lettering will be right side up, and vertical when you look at them before you start. I've actually seen haedlights that wouldn't adjust right because someone didn't make sure they were installed vertically before they started.
Old Jun 15, 2010 | 02:00 PM
Wow I ouldn't add anything to that. Exactly how I would do it. If both are pointing down. Are the front tires really short. Big shackles. Big tires. Short springs. These are also things that can cause this. If the adjusters can't fix it and the car has alot of rake you could lower the *** a tough. Hey your new here. BTW Welcome.
Old Jun 15, 2010 | 11:03 PM
Lj2069's Avatar
thanks for the help guys appreciate it. and ha yeah thanks. I'll probably need more help down the road, don't know much on how to fix stuff yet still learning.
tim dawson
Feb 25, 2019 02:24 PM
Pig Hunter
Dec 7, 2010 10:51 PM
cocanut
Oct 31, 2010 07:37 AM
JordanN
Aug 8, 2010 07:06 AM
Skippysnax
Apr 20, 2008 07:28 PM
