Holley fuel pump noise
Old 12-10-2011, 03:24 PM
It's quite possible that the OP's problem is that his exhaust isn't loud enough!
Yeah, if mine gets too loud I uncap the headers!
Old 12-10-2011, 09:04 PM
77 kencraft's Avatar
Thx for all the responses, oh its loud even over the loud exhaust and thumper cam. I have rubber between the pump and the frame, running a regulator/ no return, but I even let it run free into a can and it is still loud. Sounds like, it is what it is, can't hear going down the road so what the heck.
Old 12-11-2011, 08:15 AM
You have a rubber isolator, but is it mounted too tight? If it's too tight it wont isolate the noise, that's why I use nylock nuts to allow it to be just snug, but not tight. If your's is not mounted with a bolt and nut, then you can Loctite the bolts and just snug them.
Old 12-11-2011, 08:57 AM
I will give it a try thx
Old 02-06-2012, 09:07 PM
Texas70z28's Avatar
my electric fuel pump is noisy too,granted my interior is not all in. I have a buddy who races and said he runs high power mechanical pump and suggested i do the same. Everyone i talk to at the car shows tells me all the electrics are noisy.
Old 02-07-2012, 09:07 AM
That's correct, all but the very expensive centrifugal paumps, and they whine instead of thumping. Another trick to isolate them is to slip runner grommets over the bolts and a rubber pad under, so the metal bolt wont come in contact with the metal pump mount.
AlaJoe
02-18-2011 08:56 AM
pd411
12-13-2009 09:37 PM
sewerrat
03-24-2009 03:53 AM
riceeater
11-16-2007 06:37 PM
Quick Reply: Holley fuel pump noise
