Holley fuel pump noise
Old Dec 9, 2011 | 09:56 PM
77 kencraft's Avatar
Question Holley fuel pump noise
Hey guys, I have a holley electric fuel pump mounted back by the tank, it works awsome but is really loud. I was wondering if anyone knows of away to quite it down some.
Old Dec 9, 2011 | 11:41 PM
Not really, there just loud. Try a rubber isolator between the pump mount and the frame. Your other options are the new Eddy pump. Its supposed to be quite but I have no experience. Then there are the in tank pumps.
Old Dec 9, 2011 | 11:44 PM
Is the noise consistent, or does it change it's tune according to how you're running the engine? I haven't had a Holley elec. pump, so I can't say how loud it's supposed to be, or not. And I don't know if your idea of loud is the same as other peoples?
I presume you have a fuel pressure regulator hooked up before the carb? If it's not a return style, you could be over-working the pump, which might be the reason for the excess noise. Another option is to insulate the pump, but I'd be a little concerned with that making the motor run hotter.
Old Dec 9, 2011 | 11:47 PM
I have had three Holley blues. All sound like hell. The worst was my drag car with no interior.
Old Dec 10, 2011 | 12:11 AM
Hmmm, if it's that bad by nature, then he either lives with it, or gets a different brand. I take it, you were running return style regulators?
Old Dec 10, 2011 | 02:06 AM
No dead headed. I've been wanting a return regulator but haven't nailed down how or where I'm going to mount my pump. I may just get a Walbro if I can get one that will work with a carb.
Old Dec 10, 2011 | 08:09 AM
Then we need to find out from the OP if he's running a return or not. The pump motor runs easier when the fuel supply isn't being stonewalled toward the end of the line.
Old Dec 10, 2011 | 09:28 AM
iLL95's Avatar
I Like to Party
Super Member
OP- is it a whine sound?
Old Dec 10, 2011 | 09:56 AM
No, they make a rapid bumping or thumping noise. My pump is also set up without a return line and does the same. I simply used a piece of 1/4" rubbber and nylock nut to isolate it off the frame and it's fine. I hear it when I turn the key on, but not with the engine running.
Old Dec 10, 2011 | 09:59 AM
It's quite possible that the OP's problem is that his exhaust isn't loud enough!
