help with vents on the heat and a/c system
Old Jul 18, 2009 | 05:22 PM
kerbykk's Avatar
Default help with vents on the heat and a/c system
ok could one of you pop your hood and put your ac on and tell me if the vent on the cowl area under the hood is open or closed on the passenger side? i think it should only be open for venting in outside air but closed for ac.Then i need to know if the vent inside the car on the passenger side should be open or closed while the ac is on(this is down by the kick panel and has a cover so maybe you can feel for airflow).I think it should be open to recirculate air from the cabin.
MY blower does noot seem to be blowing hard enough even thoug i can hear the different speeds.i replaced the blower motor and same thing so i think i have a restriction somewhere.I have removed the box and made sure the flap for the heat or ac is working right and it is.the car is a 75 camaro.thanks for any info.later
Old Jul 18, 2009 | 05:29 PM
kerbykk's Avatar
cannot find ant air flow diagram
Old Jul 30, 2009 | 03:11 PM
Engine Co 350's Avatar
I have the same problem on my 71, the fan changes speed, the AC is cold, but the airflow at the vents is not very forceful.
chris.langlais
Oct 13, 2011 01:31 PM
burning camaro
Nov 9, 2010 06:15 PM
bezerker
Dec 18, 2008 05:49 PM
phillipiruss
Jul 18, 2008 02:08 AM
94CamaroSFI
Oct 13, 2006 07:48 PM
