HELP!!!! brake conversion on 69 z28
Old Nov 3, 2006 | 11:22 PM
dragger174's Avatar
Default HELP!!!! brake conversion on 69 z28
i have a 69 z28 that i drag race in a super pro class. i am in desperate need of a drum to disk conversion and i am on the verge of buying a kit ($700-1200) . i have heard that i could get these parts from a junkyard pretty cheap but i was wondering if anybody here has went through this process. thanks for any help!!
Old Nov 6, 2006 | 09:29 PM
firebird69racer's Avatar
Default RE: HELP!!!! brake conversion on 69 z28
you want them for the front or rear? A true Z/28 came with discs up front.
for the front there are a lot of different cars that will fit
Old Nov 6, 2006 | 09:34 PM
shnormo's Avatar
If you are convertering it with a conversion kit, You'll need a booster, master cylinder, and proprtioning valve. The front brakes hold 70% of your stopping power so I would just swap the fronts unless they already are. The rear should be left as drums because you'll have to do extensive tuning of the proportioning valve. The drums are also lighter.
bragg3
May 1, 2010 02:16 PM
maudyZ28
Apr 16, 2010 10:20 AM
myohann
Nov 3, 2008 07:24 PM
blackz87
Nov 24, 2006 12:12 PM
