having problems with HURST shifter
Old Jul 19, 2010 | 03:40 PM
gambit's Avatar
Default having problems with HURST shifter
My mech installed new HURST vmatic 2 shifter on my car. from park it goes into reverse and than all good, but once in gear, in straight mode from "d" bring shifter back to "n" and it stays in gear. bring it to "R" it goes "neutral" .
so every time i'm in drive and want to go reverse, i need to bring it to "park" and than do "R"
any ideas?
Old Jul 19, 2010 | 04:37 PM
Adjust the cable? Theats about all I can think of.
Old Jul 19, 2010 | 04:41 PM
Your mechanic installed the shifter, did he test it? And did you pay him to install it....correctly? Have you tried asking him? Maybe he didn't do something right, or didn't tighten the linkage arm, etc. Is the shifter you got made for your trans (3 speed I presume)? If yours is made strictly for an overdrive trans, your detents will be different. Or, is your shifter made to be used on either trans, and possibly not set up for the right one?
Old Jul 19, 2010 | 05:58 PM
gambit's Avatar
will check the cable. I really don't want to go back to the mechanic. To best of my knowledge the shifter is for my car. it replaced the older one which was same.
Old Jul 20, 2010 | 11:02 PM
Potterboy's Avatar
i had the same problem, sounds like the cable
Old Jul 20, 2010 | 11:16 PM
Sounds like play in one of the attachment points. When you go to park and then back you're basically taking up the slack of a loose point. Check the attachment points at the shifter, and the tranny.
Old Jul 20, 2010 | 11:22 PM
NYH1's Avatar
Why not? If you paid him to do a job and he didn't do it correctly, take it back and have him make it right.
The machanic should have made sure it was the right shifter before or during the installation. Like someone already said, he should have made sure it was working correctly before he took your money and gave your car back to you.
Just my $.02.
Gorn
Nov 6, 2009 05:34 AM
Pro_built7
Nov 26, 2007 08:48 PM
dumbnstupidone
Sep 20, 2007 08:08 PM
burninrubber11
Jun 29, 2007 04:20 PM
Don Hog
Oct 30, 2005 02:35 AM
