Harmonic Balancer removal problem
Old Sep 12, 2008 | 07:27 AM
1977 402's Avatar
Default Harmonic Balancer removal problem
My son has a 77 that has a 402 BB, he has puled the engine out since he wants to rebuild it.. We are at the stage of removing the Harmonic Balancer and the bolt has been removed from the balancer to the crank and has attached the balancer puller, it has moved about 1/2 an inch but has stopped, what are we doing wrong or are they all hard to come off?
Old Sep 12, 2008 | 09:11 AM
thebandit110's Avatar
Default RE: Harmonic Balancer removal problem
sometimes those balancers can be a real pain. douse it with pb blaster and than use the puller again, make sure your bolts that run through the puller and thread in to the balancer are snug and nothing is getting hung up. especially if the engine was seized it can get real stuck. try the blaster. i swear by it
Old Sep 12, 2008 | 02:11 PM
screamineagle's Avatar
The pb blaster does work great. I would say also spray that on and maybe even crank the balancer back in and spray more let it soak and then pull it should come off. They are a pain sometimes.
Old Sep 12, 2008 | 02:45 PM
tammy's Avatar
Banned
Make sure the puller is seated right at the crank and not bottoming out at the puller; Use impact wrench on puller, should come off no problem.
drifter
Aug 12, 2013 07:00 PM
1976camaro
70-81 V8 Tech
Dec 14, 2010 12:28 AM
VCA
Nov 4, 2010 10:04 PM
jarrod1875
LS Series Tech
Oct 29, 2009 12:45 PM
chrshadil
Aug 12, 2007 09:03 PM
