what gas to put in my 81 camaro?
Old Aug 29, 2008 | 11:56 PM
jason7504's Avatar
Default what gas to put in my 81 camaro?
ive been using regular unleaded, but should i get supreme or premium? my engines not knocking tho!
Old Sep 10, 2008 | 08:10 PM
jason7504's Avatar
Default RE: what gas to put in my 81 camaro?
i got my 81 camaro with a 350 like 3 weeks ago. the person i got it from said they didnt know for sure if it took regular or premium. do you guys know?
Old Sep 10, 2008 | 11:23 PM
bowtieguy's Avatar
July 2009 ROTM
if its stock ,i would run 87 octane.if you got a cam,little more compression,headers,i would think about running 91 or 93 octane
Old Sep 10, 2008 | 11:49 PM
jason7504's Avatar
ok but define stock? cuz i have headers. you mean a performance cam and headers huh?
Old Sep 11, 2008 | 06:48 PM
screamineagle's Avatar
Main thing is the compression. Thats when you start getting the spark knock is high comp with low octane. If your not hearing any spark knock your fine i think. The cam won't do to much cause my dads 69 camaro has a REALLY wild cam but has dart 64cc heads and flat tops so around 11.5 to 1 compression and it runs fine on pump gas and like i said that car is pretty nasty. Also my trans am ran ok on 87 octane but when i would go to race i would fill it with 93. Not sure that it even did much though. I think you would be fine with 87 octane my opinion
Old Sep 11, 2008 | 07:24 PM
tammy's Avatar
Banned
regular pump gas, to go to school and back
Old Sep 12, 2008 | 02:14 PM
Yep thats what i did. On my way around driving normal and back and forth to school i just put 87 in my 95 T/A it ran great that even had 11:1 compression but aluminum heads which run cooler and don't need as high of octane. But when i went to the drags i would put in the 93 or something just to give a little extra. If you go to high in octane it actually hurts it in performance if you don't have high compression etc.
Old Sep 12, 2008 | 07:58 PM
jason7504's Avatar
oh i see. thanks everyone
