Gear swap: What do you think I will run?
Old Oct 15, 2004 | 05:14 AM
Rockaholic5002's Avatar
Default Gear swap: What do you think I will run?
I own a 1980 camaro with a healthy 350, cam, intake, carb, ignition, headers, etc. I am running a 15.5 1/4 mile on street tries with a 2:56 rear gear along with a split diff. I'm swapping it out for a set of 3:90 gears from richmond and an auburn pro series posi. I will be running slicks after I do the swap. What do you think I will run
Old Dec 6, 2004 | 11:03 PM
dwkostal's Avatar
Default RE: Gear swap: What do you think I will run?
not too sure, but dont expect to get into the 14s if you are consistanly running 15.5s. it will help significantly as more driveline modifications are added, though.however, if you have run faster times, try and reach for the 14s, it is very possible.
Old Apr 23, 2006 | 09:09 PM
1969 SS's Avatar
right now, what are you 60' times and your trap speed and what RPM are you going through at?
Flextrainer
Aug 27, 2013 12:59 PM
microkid
Mar 28, 2010 02:35 PM
speedracer7291
67-69 V8 Tech
Feb 25, 2008 01:29 PM
89ROC
Jan 7, 2007 08:37 PM
CCarRocks
Nov 5, 2006 09:59 PM
