gear reducktion starter mounting problems help!!
Old Feb 16, 2012 | 03:55 PM
I don't spose you could post a couple pictures......eh, you know the rest!
Old Feb 16, 2012 | 03:59 PM
Some later starters (and gear reduction starters) take shorter bolts. It sounds like you simply need shorter bolts to make the new starter work. Be sure to get the correct shoulder bolts so it aligns the starter too! That may be part of the problem if someone didn't use the correct starter bolts.
Old Feb 16, 2012 | 04:22 PM
blowncamaro123's Avatar
the video is taking a while but it shows the flywheel and starter and when i hit the starter it doesnt turn the flywheel now
bellsz28
Mar 2, 2011 02:56 PM
rktect69
May 26, 2010 08:31 PM
79blueberry
Mar 6, 2009 09:57 AM
mindtwister
Oct 13, 2008 12:38 AM
1994z28
Nov 25, 2007 03:49 PM
