fuel pump ?
Old Jul 8, 2007 | 01:36 AM
BadBowtieZ28's Avatar
Default fuel pump ?
i bought one of the edelbrock performer series fuel pumps for my '81 Z. the sheet that came with it said i need the adapter plate that allows the fuel lines to run in the bottom of the pump due to the motor mount being in the way for 70-81 camaros. so i got the plate and my stock pump has 3 lines running to it i'm taking it one is a return line. my new pump is designed for just inlet and outlet. what do i do about the return line?
Old Jul 8, 2007 | 07:58 PM
Default RE: fuel pump ?
You could put a T fitting at the output of the pump. Depending on how the tank is vented, it may be a bad idea just to plug the vent line off.
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
