Engine Swap
Old Oct 25, 2005 | 03:53 PM
runedawg's Avatar
Default Engine Swap
I am going to swap out a tired 305 out for a new 350 with a 4 bolt main from GM. Is there anything I need to get going from a 2 bolt to a 4 bolt?
http://www.crateenginedepot.com/stor...53--P62C3.aspx
The car has a turbo 350 tranny. I am gonna get a 2bl intake of a 73 Monte Crlo from my neighbor for like $25.
Anyone want to recomend a balancer and flexplate? After I put the Balancer and flexplate on do I need to take the engine somewhere to get it balanced?
Old Oct 25, 2005 | 06:54 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: Engine Swap
No
TCI
No
Old Oct 25, 2005 | 10:29 PM
The number of main bearing bolts make no difference on installing the engine, as the outside of the engine remains the same.
The 2 bl setup is going to be very restrictive on a 350, unless you use a very large 2bl. A large 2bl gives poor throttle response at low RPM.
Old Oct 26, 2005 | 11:54 AM
runedawg's Avatar
I was looking to stay a 2 bl to keep decent gas milage.
Old Oct 26, 2005 | 01:14 PM
A four barrel will usually run on 2 barrels until you demand more power and force the second pair of barrels to open up. So it is up to your right foot as to what mileage you get. For a good compromise you can install a quadrajet which has small primaries and large secondaries. This will give you good mileage and response at part throttle, and give you full power when you call for it. You will need a manifold designed for it. The only advantage of a 2 bl is that it is cheaper than a 4 bl.
Old Oct 29, 2005 | 11:13 PM
68RSSScamaro's Avatar
I'm with z28pete on the quadrajet - There are some nice aftermarket ones out there.
Harmonic Balancers - Professional Products has a nice one and try www.tciauto.com for the flex plate.
Old Oct 30, 2005 | 04:10 PM
runedawg's Avatar
Cool. Thanks for all the suggestions.
Old Oct 30, 2005 | 07:30 PM
Adam's Avatar
If your really interested in the quadro.....I got one and an intake i'll let go for cheap....
Old Oct 31, 2005 | 05:11 PM
runedawg's Avatar
how cheap are we talking
3800_seriesII
Aug 14, 2012 07:24 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
cachaco736
Dec 11, 2007 11:12 AM
uradumass5695
Oct 21, 2006 08:27 AM
illumastar
Oct 20, 2006 01:42 PM
