which engine manifold?
Old Apr 18, 2012 | 12:36 PM
stox58's Avatar
Default which engine manifold?
HI,
As you may know i'm from England and i'm putting together a Big Block 454 for my 77 LT, i was looking at the Edelbrook performer manifold ( low rise ), as hood clearence will be tight.I have been offered the below manifold new for agood price.Please can you tell me if they are any good and would there be any difference in the height?
many thanks from Luke
Brand Professional Products
Manufacturer's Part Number 53001
Part Type Intake Manifolds, Carbureted
Product Line Professional Products Cyclone Intake Manifolds
Summit Racing Part Number PFS-53001
UPC 665053530012
Engine Block Style Stock/OEM standard deck
Carburetor Quantity One
Intake Style Dual plane
Basic Operating RPM Range Idle-6,000
Intake Manifold Height 5.750 in.
Intake Finish Natural
Intake Material Aluminum
EGR No
Old Apr 18, 2012 | 08:15 PM
5time F's Avatar
The Edelbrock will be just a bit lower under the hood... if you call .3 inch (7-8MM) shorter... They both list for $202 US on Summit... if you can get the other one for Cheap...I vote for jumping on it..... Since the Hood is the same as the 70-71 hood with a big block I would thing that this should fit without a problem.
Old Apr 19, 2012 | 01:55 AM
stox58's Avatar
I do have a 2.5inch Cowl hood, so that gives me abit more room. Is there much difference with the Carb adapters between the two Manifolds?.
cheers from Luke
G Man
Aug 2, 2017 12:33 PM
glue maker
May 24, 2009 04:05 PM
90iroc-z28
May 19, 2009 11:16 AM
mtn_maro
Oct 22, 2008 01:10 AM
trexbarney7791
Feb 5, 2008 10:13 PM
