View Poll Results: Which engine would you get?
patriot's 383 500hp/500tq
![](https://camaroforums.com/forum/images/polls/bar2-l.gif)
![](https://camaroforums.com/forum/images/polls/bar2.gif)
![](https://camaroforums.com/forum/images/polls/bar2-r.gif)
![](https://camaroforums.com/forum/clear.gif)
16.67%
United racing 383 506hp/500tq
![](https://camaroforums.com/forum/images/polls/bar3-l.gif)
![](https://camaroforums.com/forum/images/polls/bar3.gif)
![](https://camaroforums.com/forum/images/polls/bar3-r.gif)
0%
phoenix muscle car 454 455hp/492-525tq
![](https://camaroforums.com/forum/images/polls/bar4-l.gif)
![](https://camaroforums.com/forum/images/polls/bar4.gif)
![](https://camaroforums.com/forum/images/polls/bar4-r.gif)
10
83.33%
Voters: 12. You may not vote on this poll
which engine to get for my '81 camaro?
I have the Summit #SUM-380331, but you don't want that one unless you want to modify your core support and weld up new mounts. It's a little bigger than the direct bolt in, but not enough so for the amount of work I had to do to get hood clearance just so the hood would close. I'd go with Summit #SUM-380457 It's almost twice as much, but drops right into your support, and just needs the support opening enlarged. Easy fit!
I've got the Flexalite FLX-4120 from Summit for a tras cooler. It's 7.5"x20", and will handle the most extreme cooling needs. Cheap at $43.
do you think 502hp and 570tq is streetable though? and can i use my MSD HEI distributer from my small block on the 454 but i would add a 6AL box to it?
Streetable? I think it can be run on the street, but it wouldn't be my choice. As I mentioned before, it's fun at first, but after awhile that much power seems to be more work than fun. If you're determined to get it, go ahead, but lots of torque and hp mean lots of gas and repairs. My wife's brother has a 1970 Nova with 454 running dual 600's on a tunnel ram and lots of HP. Seems like he never wants to drive it when we go to a cruise in together. Always wants to take my car because it's too much hassle driving his Nova with the 500+ hp 454. You just can't relax with that much power on the street. Even the 454 is a whole lot of motor at 455hp, and I'd tend to go for the lower 425hp version myself.
The 350 and the 454 or larger displacement BBC based engines share a common distributor.
oh wow i bet thats a sweet nova
![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
Do the 305's also share a common distributor?
This is also why I'm not stroking my small block 406 to a 434. Too much trouble for the gains. After talking to a local performance shop and a couple of guys who run them they say they're good for the drag strip but not too good for a street driver. Two of the three told me that unless I want to tear it down every 8 months to a year that it's not worth it. It's different when you do a tear down after the season's over on a race car versus when you do it for your street car that you drive regularly.
Won't he have to get different motor mounts for the big block to set the engine correctly? I remember talking to bowtie guy about it and he had to use a different set of motor mounts. Does it set the engine's rear mounting surface more forward or back? If so this will change the mounting point of the transmission crossmember and it will need to be relocated.
This is what BowtieGuy said about his setup when I asked about a conversion:
Originally Posted by BowtieGuy
there really wasnt much to the conversion.i had to get motor mounts for a 76 model truck because i had one with the big block and i knew they would fit,you could probably get some aftermarket.it was a tight squeeze because i still got the air on it,passenger side header bolts and spark plugs are a ***** but it can be done.i looked all over the place for some front coil springs and finally went to the local spring shop and looked thru his books and found a set out of 455 big block trans am springs for about 100.00 ,nothing else came with a b/b and it sets level.i have a 400 turbo in it and had to move the cross member back and redrill the sub frame,no big deal.everything else fit right in.the only headers i could find that would fit were some summit brand headers because i got air,ps,pb and they fit right in,didnt have to beat and bang.you will need a big 3-4 core radiator,i have a big3 and have not had any problems,it stays about 200-205 on a 100 degree day.i had to shim the brake booster over about a 1/4-1/2" to allow for the tall valve covers. It had a 350 turbo in it and it fit just fine.I went thru 2 of them and decided it was time to go heavy duty.I used the same cross member just moved it back 6-8 inches and it fit just fine.I had to alter the shifting linkage to make it fit the 400 and i had to change yokes and shorten the driveshaft a couple of inches
I think I would have to lean towards the big block as well. My stroker is built up pretty nasty, but my car wouldn't be very much fun to drive any long distances. To get more horses out of a small block, you're really pushing it hard and to the limits. I recently got a ride in a friends BB 71 Camaro. And even though I'm pretty sure our two cars would be a fun and close match up, his just felt like it was "loafing" along compared to mine getting pushed to the edge.
And I believe the differences in the big block engine frame mounts is that they kick the engine over to the passenger side a touch to help clear the steering box and brake booster.
thanks kyphur and camaro69..ive decided on getting a BB now as well..im torn between the 455hp or 475hp 454 or 470hp/525tq 509? do you think any of these would have good street manners?
also i found out that the 509 with 470hp and 525 tq has a comp flat tapped cam with 276/282 duration and .510 lift along with 9.8:1 compression.
Ok, since I've done a few conversions in Camaros from SBC to BBC I'll tell you what I've done.
First, there's no magic to motor mounts. If you have the std. small block frame location mounts, then simply use SBC engine mounts. If you try to use BBC engine mounts, then you'll have to take the frame mounts off and change to the BBC frame mounts. Why bother, when the SBC mounts bolt right on a BBC and to the frame. Get polyurethane or Moroso solid steel, but stay away from Energy Systems SBC mounts, as they have clearance issues.
Headers or stock manifold will drop right in, and the Doug Thorley headers I used dropped right in from the top! Just pulled the spark plugs and slid them into place, bolted them up and put the plugs back in.
You'll need to reroute your alternator wiring from passenger side to driver's side, as that's what all the BBC Camaros used. The alternative is to fabricate a altenator mount for the passenger side, which is what I chose. I just mocked up a mount, tacked it together on the engine, then removed it and welded it up. I didn't want the alternator above my PS pump, so chose to do it this way. Two others used the stock alternator/power steering pump brackets and relocated the wiring. You choose what you want.
Engine location doesn't change, so nothing to change with the tranny. Simply bolt it up. I did have to change the radiator to the big one, and that meant cutting out the core support on every swap. 5 minutes with a jig saw or Sawzall. Then some filing and paint.
Anything else is optional, depending on what you want to do with the exhaust and rearend.
#20
Yeah, I think I would listen to someone who has actually done the conversion (1971BB427) over someone who has just heard second hand what it takes (me). ![Icon Bowrofl](https://camaroforums.com/forum/images/smilies/icon_bowrofl.gif)
I mean it's even in his frickin' name!
With that said I don't think you'll be upset with either choice you make as far as the BBC's go. I was wanting to go 496 but this 406 kind of fell in my lap. Now if someone wants to trade a 406 for a 454...
![Icon Naughty](https://camaroforums.com/forum/images/smilies/icon_naughty.gif)
