Engine Dedcision
Old 10-12-2010, 12:11 AM
Originally Posted by NJZ28
yea i tried to decode it from the numbers from behind the alt. but they are worn away cant read them.
Have you tried sanding the pad lightly, it may give you enough contrast if the numbers are still kinda there. You only need to catch the two or three letters of the suffix code (at the end of the # string).
Old 10-12-2010, 01:31 AM
80ZJoe's Avatar
July 2010 ROTM
Take a valve cover off and read the casting #'s on the head, might give you a better idea on what the mystery motor is.
http://www.73-87.com/chevy_ids/sbheads.htm
Old 10-12-2010, 10:13 AM
Your right. It wasn't that dark of a blue. But anyhow. What I was getting at is LOTS of people will rattle can a motor orange. Or blue for that matter. Its whats called a Mexican overhaul. No offense to anyone ethnicity. Just a name, like cracker.
Old 10-13-2010, 11:56 PM
NJZ28's Avatar
ok i have the floor pans out now and wanna get them welded in before starting another project on the car. once i do i plan on getting this motor out and getting it apart. im hoping that everything will turn out good but right now with college midterms kinda hard to sneak away to have some fun
Old 10-14-2010, 06:11 PM
From what i have read and been told that chevy used orange block from 67 up to about 75 and then from 76 to 85 it was a dark blue almost black. but from what ive seen sometimes this little rule is off but if the rule is ture my 80 shouldnt have come with a orange block
Engine paint is cheap. It's not the way to determine the year. I'm pretty sure that's what Damon meant. Anyone can paint an engine, regardless of what color it started out as.
Old 10-16-2010, 01:17 PM
NJZ28's Avatar
yea i figured that and im going to end up painting it too cause its flaking badly but hopfully i can get all this done before december because i want to start new projects!
onefastls1
01-02-2013 01:45 PM
martynlutherking
05-25-2010 11:12 PM
Chevykicksbut
10-28-2009 07:14 AM
drabina
07-25-2008 08:56 PM
jrb78
82-92 V8 Tech
11
12-16-2007 07:05 PM
Quick Reply: Engine Dedcision
