dz carb for 302 z28
So what do you really have, a complete carb or a couple of parts?
It's worth as much as you can get, depending on the condition. I would go on ebay and see if you can find any to compare to.
Ok thanks for that. I dont know what year of camaro the carb came off. And I really have just what the post says i have. The base plate, the main body and the front metering block. The number on the carb is 3923289-DZ.
Looks like it is a correct '67-'69 DZ 302 carb,not sure what it's worth but I'm sure someone restoring a Z28 might want it,off to ebay is what I'd say.
http://www.automedia.com/1969_Camaro...es20021001z2/2
Carb ID
The stock Z/28 carburetor is a Holley #4053, GM part number 3923289-DZ. Like the intake, many times this part has been replaced with a different Holley or a rival-brand carburetor. The DZ code appears again on the carb's air horn, which distinguishes the unit as a specific Z/28 carburetor. You must remove the air cleaner assembly to find this code. Anything different means that the carb is incorrect for the 290-hp Turbo-Fire 302 engine.
Carb ID
Looks like it was also used on SS 396 Chevelles etc.
http://cgi.ebay.com/ebaymotors/68-69...=p4506.c0.m245
http://cgi.ebay.com/ebaymotors/Holle...4506.m20.l1116
