Dragging Brakes (Booster Rod too long?)
Old Jun 26, 2023 | 09:51 PM
petreussg's Avatar
Default Dragging Brakes (Booster Rod too long?)
Hello,
I have a 76 Camaro with an aftermarket brake booster (previous owner installed).
My brakes keep dragging.
I have a temporary solution, but need to know a more permanent one.
My only adjustment for the booster is behind the peddle. I adjusted this all the way out to try to stop the drag. No luck. (At least I think that's the adjustment)
What I needed to do temporarily is to place a few washers between the booster and master cylinder. This is definitely not something I want permanent since I don't want stuff to get between them.
I saw online that many people have adjustable rods that stick out of the booster. Mine is not adjustable.
What do I need to do? Any ideas?
Thanks!
Old Jun 27, 2023 | 11:26 AM
You are 90% there. If it is too long then it is adjustable. Use more washers to get everything right where you want it. Then remove the washers and measure the thickness. Then just use a had grinder and shorten the pin the amount you measured or buy an adjustable one and adjust it to that length. I would go as far as putting the length in this thread so I could always find it.
One of the great things about keeping a build thread on a project is you can store tons of info. I have info in mine I know no one wants to see but if I ever need it is there. My threads go back to 2009.
Old Jun 29, 2023 | 10:36 PM
petreussg's Avatar
I’ll give that a try.
do you know if the rod is one piece all the way from the peddle to the master cylinder. Or is it a piece that goes to the booster and then another piece from the booster to master cylinder?
1967camaroventwindows
Jan 11, 2023 03:04 PM
snewma4
Jan 9, 2023 12:13 PM
Dj Aztek
Mar 18, 2010 02:04 PM
my1967kamaro2
May 9, 2007 12:59 AM
danlint
Apr 7, 2007 01:30 AM
