Contradicting engine codes on a '68???
Old Aug 14, 2006 | 11:16 AM
camss68's Avatar
Default Contradicting engine codes on a '68???
I found my engine code finally! It ends with the suffix "DN".. According to one site that makes it a 1968 307 ( http://www.chevy-camaro.com/chevy-ca...s.asp?group=10 )
On other sites it runs as a 327.. I am totally new to this so please forgive my ignorance on the subject matter.. With that said, just surfing around the internet, the smallest V-8 available on a 1968 Camaro was a 327. (Once again, this is from the info I could find on the internet)
Also, in the link I provided above, the side notes says manual transmission with a H.D. CLutch and my car is an automatic (2 speed 'Glide which codes out as a '68)
The motor was rebuilt and bored over .30, and the casting numbers on the heads put those as '62-'64 small block Chevy heads so it looks as though the heads were swpped at one point.
I would love to positively identify this motor. Any suggestions?
Old Aug 15, 2006 | 03:05 AM
firebird69racer's Avatar
Default RE: Contradicting engine codes on a '68???
this site says it could be a 59 283 in a full size, or 67 283 or a 68 307 in a Chevelle, the casting numbers might help more? Remember that the 307 had the same block as the 283 with the 327 crank
http://www.nastyz28.com/sbchevy/spcode4.html
here are a few other sites in case you havnt seen them
http://www.camaros.org/index.shtml
http://www.nastyz28.com/sbchevy/sblock.html#camaro
http://www.mortec.com/castnum.htm
Camaroboi22
Apr 9, 2013 09:14 PM
Dappled Apple
Dec 11, 2010 12:40 PM
mtn_maro
Oct 3, 2008 09:11 PM
golfballs
Aug 2, 2008 02:02 PM
bradsrs
Mar 8, 2007 02:05 AM
