Clearance issues with HEI distributor
Old Jan 25, 2007 | 04:57 PM
KTM90's Avatar
Default Clearance issues with HEI distributor
I have a 69 that I plan on putting a GM350 crate engine into. The engine comes with a HEI distributor but I have been told that it will hit the firewall. Has anyone else had this problem? Any work arounds? Thanks.
Clint
Old Jan 25, 2007 | 11:56 PM
69camaro1's Avatar
Default RE: Clearance issues with HEI distributor
Yes you just have to pound out the firewall some, if that dosn't bother you.
Old Jan 26, 2007 | 01:49 AM
bowtieguy's Avatar
July 2009 ROTM
ya,just beat the dog sh#@ out of it.it will move.in the end you will have your clearence and it want look to terribly bad
Old Jan 26, 2007 | 06:42 PM
mcmcmahon's Avatar
If your car has points in it now you will need to bypass the resistor wire .The Camaro resistor wire is a white braded looking resistance wire in the harness. The easy way is to run a new wire from the fuse block inside, come off the "ign" terminal and run to the coil power terminal. I put h.e.i. in mid 90's, and still regret bashing in fire wall with 5 pound sledge hammer, i'm goin to fix mine and installstock looking electronic distributor. Its your choice.
Old Jan 27, 2007 | 08:34 AM
skar's Avatar
I think I will go with a MSD distributor and box. ? will the MSD distributor fit.
Sydthebarrett
Jul 25, 2012 01:57 AM
87STROKER-Z
May 28, 2011 04:24 PM
red star
Feb 26, 2011 11:14 AM
Jr. Mechanic
May 23, 2010 10:22 PM
EdgePerf
67-69 V8 Tech
May 6, 2009 12:46 PM
