Car won't start or turn over
hi guys i'm new to the forum and i have a '76 camaro and it won't start or turn over i have already replaced the starter and the ignition switch assembly. can't figure out the problem and suggestions would be helpful.
We tried to ground the engine but the the engine still didn't turn over. as for the starter its brand new as well as the ignition assembly and the wires seem intact and the battery is on a charger. where would i find the neutral safety switch? thank you
You have a combination neutral safety/reverse light switch. Assuming you have a console shifter, the switch is in there. Or if a column shifter, it's mounted down on top of the steering column. Are you saying the reverse lights are on while not in reverse? Your switch and/or mechanism is messed up then.
